Speaking of Precision Blog
Previous in Blog: How Does Your State Rank for Manufacturing?   Next in Blog: Gloves and Grinders – UNSAFE OSHA
7 comments
Carbon Steel Without Manganese?
Posted August 05, 2014 11:00 AM by Milo
Pathfinder Tags: manganese manufacturing roll steel
Manganese ties up Sulfur before it can chemically combine with Iron to form Iron Pyrite. Iron Pyrite occurs at grain boundaries and leads to hot shortness (brittle behavior) at rolling temperatures.
More than fools gold, Iron Pyrite can prevent steel from being hot worked by inducing "hot shortness."
We saw that several people found our blog with the search term "Carbon Steel Without Manganese."
So we'll take this opportunity to answer that.
We have already written about 5 Facts about Manganese in Steel which explains the contributions of Manganese to a steel's properties.
But lets answer the question - is there a Carbon Steel without Manganese?
The answer to that is No.
Here is the primary reason why. Iron Pyrite.
There are always small amounts of sulfur in steel, and Sulfur combines with the iron in the steel to form Iron Pyrite. Iron Pyrite is also known as iron sulfide, though a more descriptive name might be Iron persulfide.
Regardless, this material is formed as sulfur in the melt reacts with iron , and this material segregates at grain boundaries., causing intergranular brittleness. This causes it to break, rather than behave in a ductile fashion and reduce under the pressure of the rolls.
By adding Manganese to the melt, Manganese preferentially ties up the available sulfur, forming manganese sulfides. this prevents the formation of iron pyrites in the grain boundaries, preserving the ductility of the steel at rolling temperatures.
That is why every steel that we have encountered contains enough Manganese to react with the sulfur in the melt.
Steel without Manganese? Nope, I've never encountered it. And that is a good thing!
Photo credit
Editor's Note: CR4 would like to thank Milo for sharing this blog entry, which you can finish reading here.
Re: Carbon Steel Without Manganese?
08/05/2014 12:21 PM
According to Wiki, steelmaking consumes 85%-90% of the global Mn demand. Is there a current or foreseen shortage of Mn that might be driving this interest in Carbon Steel Without Manganese?
Good Answers: 243
08/05/2014 12:45 PM
I thought that the search originated in India where someone trying to break into the steel business just paid the ir ferromanganese bill and wanted to know if there was a different recipe they could use to avoid paying for the Manganese.
But 80% of the manganese in the market comes from south Africa. Us sources of manganese are largely from Gabon, but ferromanganese from South Africa as the major supplier. also found in Ukraine (HMMM???) China, Australia and Brazil. so to your point it could have been a response to geopolitical forces.
Thanks for challenging the assumptions!
Milo
08/05/2014 5:58 PM
If that were the case we would have seen the question asked on CR4.
Good Answers: 243
08/05/2014 6:02 PM
08/06/2014 11:08 AM
HA!
08/08/2014 7:20 AM
How about stainless steel and various other types of steel? Do even they have to have maganese?
Good Answers: 243
08/08/2014 10:59 AM
great question Typically Manganese content in stainless steels is over 1% by weight. 20Mo-4 stainless, 410,431,440C, and 17-4ph are 1%; 303, 304, 316 2%;18Cr-2Ni-12Mn runs 11-14%.
I have seen some solenoid grades (Carpenter 430F solenoid quality) at 0.80% Manganese.
Manganese is needed to tie up the sulfur as we discussed; it also contributes to carbon equivalent for hardenability and by combining with sulfur assists in chip breaking during machining.
Milo
Register to Reply 7 comments
Doorman (1); GameJudge (1); jack of all trades (1); Milo (3); Seena (1)
