All water, prior to being treated, contains some amount of
waste in suspension. The removal of said waste, whether it be natural (as in
water coming from a source such as a river) or true human waste water, is the
goal of purification treatment plants. Recently, the technology used to
eliminate harmful products from water has received a boost from an engineer at
the Missouri University of Science & Technology.
The new system, developed by Dr.
Jianmin Wang, has improved existing technology on two fronts. The amount of
energy used in waste water treatment seems minimal when compared to total
national energy consumption, but any energy savings makes systems more
affordable in poorer regions of the US and around the world. An anaerobic
system, one which does not require the amount of oxygen of traditional aeration
technology, could cut energy requirements by 10%. Wang has also used this
system to significantly reduce the amount of phosphorous and nitrogen
byproducts. Current systems have been known to cause adverse environmental
reactions such as algae blooms due to excess phosphorous and nitrogen
contamination.
Other systems being developed by Dr. Wang would allow
soldiers on the battlefield to safely turn waste water into potable water,
reduce the size of a treatment plant so that it could be transported to regions
in need of waste water management and increase the water quality of the
effluent. These advances further the dream of providing clean drinking water worldwide
the absence of which is a primary contributor to disease spread and poverty.
The scarcity of clean water could be greatly lessened if "used water" sources
could be cleaned given the decreased energy requirements required by Dr. Wang's
inventions.
Reference
Missouri University of Science and Technology. (2015,
February 20). System to turn wastewater into fresh water developed. ScienceDaily. Retrieved February
20, 2015 from www.sciencedaily.com/releases/2015/02/150220110832.htm
