Aerospace Blog Blog
Aerospace Blog
Previous in Blog: Aerospace Industry's Balancing Act: Maintaining a Modernized Fleet   Next in Blog: Lasers Lock on to Cosmic Debris
20 comments
Can an Aircraft ‘Disappear’ in Flight?
Posted June 02, 2015 8:31 AM by CR4 Guest Author
This is a topic that has been widely discussed especially after the 'disappearance' of Malaysia Airlines flight MH370. Many aircraft passengers have always flown in confidence knowing that they are using one of the safest and most sophisticated forms of transport, which even if not 100% safe, has some excellent safety measures. The disappearance of the aircraft was therefore a shocker, not because it is the first flight ever to go missing, but because it's not expected to happen in this modern era.
image credit
Prior to MH370's disappearance, several other aircraft had gone missing. In most cases there was some explanation. Most of the disappearances happened long ago--before most of the sophisticated technology in use today. Other occurrences happened in the in famous Bermuda Triangle, a region that claims a number of disappearances without a trace and whose mystery has never been solved. Save for those instances, most of the other aircraft which were reported missing were found, save for cases like Varig's B707 and Angola Airline's B727, which are both linked to theft.
It's incredibly rare for an aircraft to disappear in the 21st century. To make this happen I think it would require expertise and planning; it could not happen by accident. To make an aircraft disappear in front of thousands of eyes is a fete that can only be achieved with some training.
To achieve this, one has to bypass a number of redundant systems. To get past the Air Traffic Control you first have to switch off the aircraft transponders, which requires some technical know-how, then plan a route that will take you through the blind spots of the primary radar. The primary radar has a limited coverage of 240km from land which makes avoiding them a possibility.
Eventually the aircraft must land and that is where the problem comes in. These are not the only systems that you must try very hard to evade, we also have the ACARS, Aircraft Communication Addressing and Reporting System, whose main role is to send data to ground stations for analysis of the aircraft's systems giving an indication of any problem that appears in flight including tampering with the aircraft's electrical systems vis-a-vis the transponders. The ADS-B, Automatic Dependent Surveillance Broadcast, is another location system which you must plan on how to evade. Although this is a futuristic technology that is expected to replace the radar, it is already in play in online flight-tracking sites.
The disappearance of the MH370 has so far proved that most of these systems can be bypassed leaving no traces. Although many disappeared aircraft are usually found crashed after a period of time, the MH370 is still a mystery to aviation experts and until it is solved, this remains to be the most successful disappearance of all time.
Re: Can an Aircraft ‘Disappear’ in Flight?
06/02/2015 10:28 AM
This article needs some much better editing. One should not say "no aircraft has ever disappeared in the 21st Century" and then cite incidents where an aircraft disappeared in the 21st century. This destroys the credibility of the author. I do agree that we have the technology to make a commercial aircraft disappearance a virtual impossibility. I also agree this technology is not being universally used in today's aircraft.
However military stealth aircraft is clearly designed to make aircraft deliberately disappear. Smugglers and other criminal activities will also try to avoid detection. So implying that this cannot happen is denial in the purest sense.
Then there will always be the completely unexpected freak scenario that surprises everyone to explain what happened.
06/02/2015 1:17 PM
Thanks for pointing out the discrepancy. The article has been edited to correct this point.
06/03/2015 3:08 AM
I suggest the blog needs not better editing but a more logical essay plan:
1. To answer the question - yes, an aircraft can disappear without the quote marks
2. To explain why
- primary radar has limited coverage of the world, with a notably large gap over the oceans
- secondary radar and other current reporting systems are not designed for 24/7 position reporting
3. To offer suggestions for the future, with estimates of cost
- ground/water based
- satellite based
06/03/2015 7:34 AM
My quote was from the original unedited article. (Thanks SavvyExacta for editing out the contradiction.)
06/02/2015 2:40 PM
Alien abduction.
Good Answers: 97
06/02/2015 5:11 PM
One shot down and then one disappears, same airline.
CRTL-Z
06/05/2015 3:05 PM
In the whole entire world, there is no such thing as a coincidence when juman nature is present. Misappropriation of the depth of the English language is not a coindidence either. Disappear has varied connotations. Crashing into the water is not really the same as visually disappearing, and neither is being shot down. Being undetectable, either visually by camouflage, or electronically by low radar cross section is not the same as disappearing. Just because something is not detectable, that does not preclude its presence within the system containing the experiment. The detector can be faulty, or improperly "tuned" to "see" the object.
To disappear (IMHO) means that what was there just a short increment of time ago, is no longer "in the sandbox".
06/05/2015 3:08 PM
Kind of like a TARDIS?
J B
06/05/2015 3:16 PM
More like the whole blogosphere just went from being one screen wide to three rooms wide.
06/05/2015 4:01 PM
Once again this comes down to proper editing of how one describes an airplanes disappearance. An airplane can safely disappear into a cloud bank when taking off on a rainy day. Any airplane can disappear out of sight by flying beyond the horizon. A fighter airplane can still disappear in a dogfight by flying into the sun. A stealth aircraft can disappear from radar by turning their transponder beacon "OFF". The F14 Tomcat has disappeared from all the skies from obsolescence.
Good Answers: 153
06/03/2015 5:34 AM
"Can an Aircraft disappear in flight". This is a serious topic and I apologize for treating it with levity. No, unless someone has invented an anti gravity device, the flight has obviously been terminated just before or at the point of disappearance.
06/03/2015 6:05 AM
This is dumb. Planes do not disappear unless they hide out in clouds and cannot be seen. But of course there are many places where a plane cannot be tracked by all reporting systems and sometimes none at all.
But even given that, to say a plane disappeared is for callers to Coast to Coast a.m.
06/03/2015 9:51 AM
Aircraft can 'disappear' fairly easily:
  1. Fly below the 'radar ceiling.'
  2. Fly into a 'shadow zone' where 'line of sight(1)' to aviation communication towers is blocked. (Often overlaps with being 'below the radar ceiling.')
  3. Congratulations, you've disappeared.
Unless the plane is flying into a mountain(2), it's likely that they will go though this while making an emergency landing and/or/crashing.
There are other ways to 'disappear' a plane, such as 'sudden disassembly' of the vehicle due to a severe mechanical flaw, or contact with airborne munitions, either aggressive or 'friendly.'(3)
Notes:
  1. Planes do not use satellite communications, beyond GPS navigation (which is a one-way signal), so they need line of sight to towers to stay in contact with the airports and control stations. Remember that radio waves have different 'line of sight' rules than 'visible light,' but if there is no 'line of sight,' there is no communication.
  2. There are only tree things on this planet that a plane could crash into while still in view of radar: mountains, tall buildings, and other planes. And most of those have made the news recently enough that any mention is a 'painful reminder.' But we cannot ignore a safety issue just because we feel sad thinking about it.
  3. Again, I'm trying to be polite and not insensitive to recent tragedies, but some things need to be said, or we end up ignoring elephants in the room while people are still getting stomped underfoot.
06/07/2015 3:52 AM
"Notes:
  1. Planes do not use satellite communications, beyond GPS navigation (which is a one-way signal), so they need line of sight to towers to stay in contact with the airports and control stations. Remember that radio waves have different 'line of sight' rules than 'visible light,' but if there is no 'line of sight,' there is no communication."
Er.... no. Planes /do/ use satellite communications for a number of applications. Or airliners do, anyway. Firsly there's the telephone system for passengers and crew then there's the Satellite Data Unit which the ACARS uses for in-flight fault reporting. What we know of MH370's position is from the ping times of the several contacts between the Inmarsat satellite and the SDU on the plane which gives us the distance of the aircraft from the satellite.
The aspect of both MH370 and AF447 that continues to amaze me is the ignorance of the implications of satellite communications systems by airline staff. Malaysia staff telephoned MH370's cockpit telephone at 02:39 and 07:13. Both times the call went through to the plane but was unanswered. Both times the call setup yeilded some useful position information. If staff had known more of the system they would have called, hungup, called, hungup, continually knowing that they were creating a log that would give them some idea of the aircraft's position.
Even more bizarrely, AF447 generated 23 Error messages, relayed to Air France by satellite, on its way down including "Failure: Electric Flight Control System #1-#2, Flight Control Primary Computer #2, ADIRU #1, comm. Air Data Reference #1-#2 to FCPC #2 have failed" (02:13) and "ADVISORY CABIN VERTICAL SPEED" [cabin pressure changing rapidly] (02:14). I thought it was bad enough there was no system watching error messages and alerting if a critical message or significant grouping occured after all, the plane had just sent messages saying "loads of important systems have failed and we're dropping out of the sky". You'd think that worthy of notice. However, even when the flight was overdue no-one thought to check the error logs until some time later. The log timing alone would have given a pretty good indication of where the plane was rather than having search planes pratting about over half of the Atlantic Ocean.
Good Answers: 97
06/03/2015 10:01 AM
Disposition of persons onboard the aircraft can make it "disappear".
Political status of persons onboard can make it "disappear".
Co-ordinated media efforts can make it "disappear".
CRTL-Z
Good Answers: 179
06/03/2015 12:07 PM
Yup, gotta watch out for those massive Alien Mother Ships that swallow-up Jumbos.... LMAO!
06/03/2015 12:54 PM
Given the fact that Flight MH370 managed to elude multiple systems, it would seem
to me that there had to be some very well informed hi-jackers involved in the
disappearance of the airplane. Whoever caused the airplane to disappear did their
homework very well.
06/03/2015 2:47 PM
You have "hit the nail on the head" on the crux of the problem with many conspiracy theories in general here. The probability that a hijacker could intentionally circumvent the multiple tracking systems available to safely land this plane somewhere without anyone telling versus something going wrong at the wrong time causing the plane to crash somewhere that systems cannot see. Both of these scenarios are very unlikely. It can be argued which is more likely until wreckage has been found.
06/04/2015 7:39 PM
Yes, it's a big, deep, dark ocean and a fast moving aircraft can travel a good distance in a short time.
06/07/2015 8:51 AM
Disappear is not the same as not found.
If I lost my diamond ring, and decide to exclusively look on 1st street, and continually look for it there no matter what, when I don't know it's lying somewhere on 3rd avenue, it is not 'disappeared'... i'm just to ignorant, stupid, or prideful to change my search area.
Same as this incident.
The investigators are convinced where the flight went down, when it crashed at another location. There is enough evidence to place the aircraft several hundred miles from the search area.
With the additional layer of politics regarding the religion, mental state of the pilot, and the absolute pride of the investigative leadership looking to be 'right' and 'first' in finding the crash adds to to silliness.
The plane has not disappeared. It is findable.
"Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth." - Arthur Conan Doyle
adreasler (1); Brave Sir Robin (1); CaptMoosie (1); evanmjones (1); James Stewart (2); JBTardis (1); jhhassociates (1); Massey (1); mawendt (1); phph001 (1); redfred (4); RG2 (1); Rixter (1); SavvyExacta (1); Unredundant (2)
