Speaking of Precision Blog
Previous in Blog: It's Not One Thing   Next in Blog: Heat Treat Colors of Steel Chart
2 comments
30 Potential Causes of Part Length Variation On Screw Machine Parts
Posted September 08, 2015 1:00 PM by Milo
Pathfinder Tags: machining part length variation
There are many different ways that part length can vary when using a cut-off tool on Multiple Spindle Automatic Screw Machines.
Here are some of the major reasons grouped into a rough classification by where the cause exists.
The Cut-off Tool itself
  • Tool is dull
  • Tool is improperly ground (point angle too large)
  • Tool loose / improperly inserted into holder
  • Tool Blade too thin
  • Cut-off tool hitting while in high speed
  • Cut off tool being hit by die head or chasers
The Cut-off Tool Holder
  • Tool holder itself is loose
  • Tool holder is hitting work spindle
  • Tool holder is hitting tool post
  • Tool holder is warped or bent
  • Tool holder is worn
The Work Spindle
  • Spindle has end play
  • Spindle has worn bearings
  • Spindle carrier has end play
  • Index Lock Pin Spring is broken
  • Finger holder not adjusted properly
  • Broken pins or fingers in finger holder
  • Feed tubes bent or beat up
  • Wrong stock feed cam- Overfeeding stock will cause bounce back from stock stop resulting in short part
  • Incorrect collet tension
The Cross Slide
  • Cross slide play
  • Cross slide loose
  • Cam is loose
  • Cut off cam too large causes too much feed
  • Cam Drum is loose
Other Tools
  • Stock pushed back into collet by drill (dull drill pushing stock rather than cutting chip)
  • Stock pushed back into collet by reamer
  • Face-off tool is loose
  • Face-off tool is dull
  • Face-off tool holder is loose
  • Die head pulling stock out of collet making part long
Part length can occasionally go awry when using cut-off tools on automatic screw machines.
This post lists over 30 reasons that I can think of- what did we miss?
Photo Credit- Acme Gridley Multiple Spindle Bar Machine Manual First Edition 1961 page C11.
Good Answers: 266
Re: 30 Potential Causes of Part Length Variation On Screw Machine Parts
09/10/2015 12:15 PM
Human error
09/15/2015 12:39 PM
This is a good start at understanding the process. Listing all of these sources of variation now allows us to ask the questions that will prevent the variations.
For example:
How can we predict when a tool will become too dull to use? How can we prevent dull tools from being used?
How do we prevent improperly ground tools from being used in the process? How do we prevent tools from being improperly ground?
How can a tool be improperly inserted, and how can that be prevented or, preferably, made impossible?
And, for ozzb, how can human error be introduced into this automated process? How can we prevent this (these) error(s)?
Register to Reply 2 comments
