Derivations Blog
Derivations
Previous in Blog: Stars With the Mass of a 100 Suns   Next in Blog: Jupiter Struck By Asteroid...Or Something
5 comments
VFTS 102 - Fastest Known Rotating Star
Posted March 29, 2016 8:24 AM by Bayes
Everything is Spinning!
Our Sun rotates once every 24.47 days. Since the Earth is in orbit around the Sun the rotation appears to take 26.64 days (synodic rotation). This means that the Sun rotates at 7,189 km/hr at its equator. That's pretty fast, but nothing compared to VFTS 102.
Some Stars Faster Than Others
VFTS 102 is a star located in the Trantula nebula, a star forming region in the Large Magellanic Cloud, a satellite galaxy of the Milky Way. VFTS 102 rotates at 2,000,000 km/hr, roughly 280 times faster than our Sun. This is the highest known rotation velocity for a star, though faster is possible.
The resulting centrifugal force tends to flatten the star; material can be lost in the loosely bound equatorial regions, allowing for the formation of a disk. The spectroscopic observations seem to confirm this due to emissions from the equatorial disk of gas.
Stars like VFTS 102 had been predicted by theorists. In theoretical models, the extreme rotational speed is caused by the transfer of material from a companion star in a binary system. After this "cosmic dance", the donor star is predicted to explode as a supernova. The spun-up companion instead is likely to be launched out of the orbit and move away from its stellar neighbors at high speed. Such a star is called a runaway. VFTS 102 fits this theoretical model very well, being found to be a rapidly rotating runaway star and lying close to a pulsar and a supernova remnant.
Re: VFTS 102 - Fastest Known Rotating Star
03/29/2016 9:35 AM
Conservation of angular momentum at work!
The Engineer
Good Answers: 129
03/29/2016 9:51 AM
03/29/2016 7:06 PM
Our Sun rotates once a day in Sundays.
03/30/2016 8:11 AM
Does VFTS stand for "Very Fast Turning Star"?
03/30/2016 10:15 AM
The rotation rate of the sun is just an average. Because it is made of gas, different parts of the sun rotate at different speeds.
"Solar rotation is able to vary with latitude because the Sun is composed of a gaseous plasma. The rate of rotation is observed to be fastest at the equator (latitude φ = 0 °), and to decrease as latitude increases. The differential rotation rate is usually described by the equation:
where ω is the angular velocity in degrees per day, φ is the solar latitude and A, B, and C are constants. The values of A, B, and C differ depending on the techniques used to make the measurement, as well as the time period studied.[1]A current set of accepted average values[2] is:
A= 14.713 ± 0.0491 °/d
B= -2.396 ± 0.188 °/d
C= -1.787 ± 0.253 °/d "
Reference: https://en.wikipedia.org/wiki/Solar_rotation
Bayes (1); Brave Sir Robin (1); Rixter (3)
