Derivations Blog
Derivations
Previous in Blog: How to Use Python to Teach Physics   Next in Blog: Awash in Starlight - Flying Through the Shadow of the Moon
4 comments
Quantum Physics and Chaos Theory Linked
Posted July 18, 2016 10:33 AM by Bayes
I came across this interesting article. It really is cool to see quantum physics get tested at a fundamental level and see new features emerge. I have always been fascinated by chaos and I am thrilled to see quantum mechanics linked to it. Here is the article:
Physicists blur the line between classical and quantum physics by connecting chaos and entanglement
Using a small quantum system consisting of three superconducting qubits, researchers at UC Santa Barbara and Google have uncovered a link between aspects of classical and quantum physics thought to be unrelated: classical chaos and quantum entanglement. Their findings suggest that it would be possible to use controllable quantum systems to investigate certain fundamental aspects of nature. "It's kind of surprising because chaos is this totally classical concept -- there's no idea of chaos in a quantum system," Charles Neill, a researcher in the UCSB Department of Physics and lead author of a paper that appears inNature Physics. "Similarly, there's no concept of entanglement within classical systems. And yet it turns out that chaos and entanglement are really very strongly and clearly related."
Initiated in the 15th century, classical physics generally examines and describes systems larger than atoms and molecules. It consists of hundreds of years' worth of study including Newton's laws of motion, electrodynamics, relativity, thermodynamics as well as chaos theory -- the field that studies the behavior of highly sensitive and unpredictable systems. One classic example of chaos theory is the weather, in which a relatively small change in one part of the system is enough to foil predictions -- and vacation plans -- anywhere on the globe. At smaller size and length scales in nature, however, such as those involving atoms and photons and their behaviors, classical physics falls short. In the early 20th century quantum physics emerged, with its seemingly counterintuitive and sometimes controversial science, including the notions of superposition (the theory that a particle can be located in several places at once) and entanglement (particles that are deeply linked behave as such despite physical distance from one another). And so began the continuing search for connections between the two fields.
Article Continues Here
Re: Quantum Physics and Chaos Theory Linked
07/18/2016 10:47 AM
Sounds like we're just one cup of hot tea away from an Infinite Improbability Drive.
07/18/2016 12:56 PM
Quantum systems may behave chaotically, but chaos is a pure mathematical concept and doesn't need physics, classical or quantum. It's just a result of iteration and nonlinear feedback. A chaotic sequence can be generated by repeatedly hitting the "cos" key on your calculator (in radian mode).
07/18/2016 11:25 PM
I'll have to re-read this several times before it can sink in to this old classical physics mind...
Does the Illustration have anything to do with the experiment? If so, some explanation is in order.
07/19/2016 5:24 PM
You're right, the picture explains nothing.
Here's where ScienceDaily got it from, I think. It's still pretty confusing. I haven't had time to watch the video. Maybe that will help.
https://www.scienceandnonduality.com/entanglement-chaos/
dkwarner (1); Rixter (2); Usbport (1)
