Building & Design Blog Blog
The Building & Design Blog is the place for conversation and discussion about building projects, tools and equipment, materials and hardware, and environment & energy. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Damper Keeps "Lights On" During Earthquake   Next in Blog: Power from Dam Conversions
10 comments
Short Seawalls Send the Wrong Message
Posted October 10, 2016 12:00 AM by Engineering360 eNewsletter
There's little doubt that seawalls are an effective deterrent to coastal floodingcaused by tsunamis. But according to a new report from Engineering 360, seawalls that measure less than five meters in height are not nearly as effective as those higher than five meters. Researchers at the Department of Industrial and Operations Engineering at the University of Michigan suggest that the shorter seawalls might cause greater damage to people and infrastructure due to the false sense of security they instill in a population that doesn't feel the need to evacuate during emergencies.
Editor's Note: This news brief was brought to you by the Building & Design eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: Short Seawalls Send the Wrong Message
10/10/2016 5:25 PM
A flood control version of a restraining order...
10/10/2016 6:26 PM
The purpose is to keep water back, not keep dogs off the boardwalk (wry humor intended).
10/11/2016 10:09 AM
Yes, it is true.
Short border walls are not as effective as tall border walls at keeping out the tsunami of an impending flood.
10/11/2016 11:59 AM
And someone spent how much on a study to prove a tall wall is better at stopping a very tall wave than a short wall? Add to that the further study to prove people felt safe when any wall is in place, even one too short. Like that isn't obvious. Some of these studies these days....
Good Answers: 40
10/11/2016 2:09 PM
They did not spend all-that-much (on this study):
it was happy hour, so the beer "waves" were pretty cheap. And the "sticky-notepad" (short wall) versus telephone directory (high wall) were no less "representative".
It's an easy-sell , for the wanna-be-wall-builders: more is better.
. . . but . . . my inquiring mind wants to know:
. . . which one is most likely going to simply "snap-off/bowl-over", and, in the end do very little (but toss money down the terlet)...?
And which would at least hold-back "something", hopefully minimizing the damage that would otherwise occur? There must be a limit to how many cubic miles of concrete can be poured-into such beasts... so: "pick any given HEIGHT". Without any lateral bracing, chances are it's a failure from the start. Thus, some of that *height* could/would/should go into such bracing, behind, as well as secondary efforts... (too many possibilities to mention).
Just axin' . . .
10/11/2016 2:34 PM
I just had to rant. I get a letter from Penn State every week on the research being done there, and quite frankly, at least once per month there is a research that has very obvious results without a study. I guess we must confirm EVERY belief these days and actually put percentages and numerical results to it. Or maybe they are just running out of ground breaking insights to research.
Good Answers: 40
10/11/2016 3:26 PM
"maybe they are just running out of ground breaking insights to research"
I guess Congress should build them a state-of-the-art Materials_Plant, affording unlimited resources for raw goods, with which they can work-out the recipe for Urani-Tung-Bestos.
[[Of course, both "UltraForge" and "UltraQuench" (as well as a few other processes) will need to be re-defined before success will be reached.]]
But "when-they-do"... I shall be happy to turn-over (my) plans for a ship to retrieve all the "free energy" civilization will ever need, from the core of the sun. (The secret: the design reaches its target 'naturally', thanks to gravity... then, is provided free "unlimited" energy with which to return...) ... [-5 already given]
10/11/2016 3:21 PM
Okay, how did this happen? How did this blog (and title) draw the opposite conclusion from the other Engineering360 blog on the same research?
The author of this particular blog appears to have decided they knew where this article was going midway through the third paragraph....and stopped reading.
Completing the third paragraph would have been very enlightening. The second half of the quote results in the polar opposite of this blog author's assumption...
"However, our results cast serious doubt on this theory. The presence or size of seawalls and coastal forests does not strongly influence residents’ decisions on whether or not to evacuate.”
Researchers at UM are not suggesting shorter sea walls may cause greater damage, they are casting doubt on that theory.
10/11/2016 3:31 PM
Seawalls more than 5 meters high were shown to reduce damage, and more specifically, walls of 10 meters in height were associated with a 5% to 6% decrease in destruction rate. However, seawalls less than 5 meters high appear to have encouraged development in vulnerable areas and exacerbated damage.
Read the linked article again and get to the fourth paragraph copied above.
I have to admit, I too came away with a belief that both pro and con were presented for the short seawalls. Perhaps the linked article was written by a committee.
10/11/2016 8:12 PM
So, I reread.
I still come away with ambiguity as to the intended take away as well as whether or not this is valuable.
70AARCuda (1); ndt-tom (2); Phys (3); Rixter (1); tonyhemet (1); truth is not a compromise (2)
