Editor's Desk Blog
Editor's Desk
The editors of Engineering360 and Electronics360 will share their thoughts with you in this blog. Check back for sneak peaks, behind-the-scenes, and insight.
Previous in Blog: Amazon's Bezos Unveils New Rocket Design   Next in Blog: Impact of an EPA Rule Rollback
8 comments
Engineer's Guide to Corrosion, Part 1 and 2 Now Available!
Posted October 13, 2016 11:54 AM by wagman262
Parts 1 and 2 of our series on corrosion basics are available. Part 1 can be found here. And Part 2 can be found here. Weigh in with your comments!
Re: Engineer's Guide to Corrosion, Part 1 and 2 Now Available!
10/14/2016 1:11 AM
I read in the text that on stainless steel, an oxide layer develops and if I understand the text correctly, pitting can occur if there are impurities in the water.
It doesn't say what kind of impurities that those are, or maybe I misunderstood something.
Also, can or could distilled or purified water be used so there would not be impurities ?
For the most part, this article was written in a very easy to understand format.
10/14/2016 2:11 PM
I will be addressing the impurities in Part 3, and perhaps an extension of this series if interest continues. The leading impurity that causes problems with stainless steel is chloride. It can penetrate SS oxide layers and set up localized corrosion cells that can cause very rapid through-wall penetrations. I have seen microbiologically influenced corrosion (MIC) in stagnant waters also cause rapid SS failure.
10/14/2016 1:43 PM
The grade of stainless you are referring to must be addressed.
10/14/2016 2:15 PM
Yes, the type of stainless (and other steels) has an important effect on corrosion. Different grades have different alloying elements, and these greatly influence the properties of steel. Parts 1 and 2 of the article were to set the stage for some of the basics. More details will be upcoming in Part 3, and perhaps further continuation depending upon continued interest.
10/18/2016 11:00 PM
I live on the beach, do you have any tricks to keep my brake rotors from rusting?
10/19/2016 8:38 AM
If you live on the beach, maybe you can wax them down like surfers do to their boards to get grip.
10/19/2016 11:41 AM
Sex wax?
10/20/2016 2:24 AM
Would be worth a try and blog for CR4.
Dont forget the video!
Eagerly waiting for your post!
Here is another option.
Brad Buecker (2); C-Mac (1); IdeaSmith (1); SolarEagle (2); tonyhemet (2)
