TechnoTourist’s Engineering Expeditions Blog
Want to travel the world, but don't have time to leave the office? TechnoTourist is here to save the day! Tag along while TechnoTourist visits famous engineering feats around the world. TechnoTourist will also investigate fascinating technologies that help to preserve and discover incredible travel locations. Maybe you could use TechnoTourist's insights to help you plan your next travel itinerary, or escape from the stresses of everyday life!
Previous in Blog: The Eiffel Tower: Born to Be Wild   Next in Blog: How Exactly Do You Walk Like an Egyptian?
2 comments
Pisa: We All Need Someone To Lean On
Posted August 15, 2007 6:00 AM by TechnoTourist
Especially you, buon amico. Your boss just called. Your next project has a projected lifespan of 200 years. Aren't you glad you just had a vacation in Paris? Welcome to Pisa, Italy!
Your next project, a cathedral bell tower, should have a hollow center with a spiral staircase that allows visitors to ascend precisely 294 steps. Not one more. Not one less. The elevation of these 294 steps should be approximately 185 ft. In addition, the cathedral bell tower must be made of at least 16 types of stone. If necessary, you can transport these building materials to the construction site by water.
Do you recognize this famous tower? La cittadinanza of Pisa certainly do. If you could ask them, they would tell you that the specifications are for the freestanding bell tower next to the cathedral. This tilting giant is a must-see attraction in the Campo dei Miracoli (Field of Miracles), a vital region in the heart of Tuscany.
So, citizens of Pisa, let us ask you this. If the Leaning Tower of Pisa was built over the course of 200 years, why does it lean so much?
Whether it was the building process or the area's unstable ground, it's clear that the Leaning Tower of Pisa secures much of its fame from its unique disposition. The base on which the La Torre di Pisa was built is only 10 ft. thick. Clearly, this isn't enough support to prevent an immense, 14,500-ton tower from sinking into soft clay and sand. Maybe that's why the Tower of Pisa was already tilting before its completion. At one point, it was leaning 4 ft. 7 in. shy of vertical!
The tilt to the Leaning Tower of Pisa proves that its blueprints weren't as thorough and well thought out as they needed to be. The bell tower's architects tried to correct their oversight prior to the tower's completion, but trying to fix their mistakes only led to a curve in the tower's structure and more instability. Although restoration efforts have been necessary since 1398, the most impressive attempt is the current monitoring system.
Since 1991, scientists have been "well inclined" to realize that they need to monitor the factors which affect the tilt of the Leaning Tower of Pisa. Efforts to save this renowned structure have been extreme, ranging from 600-ton lead weights, rings with iron cables, and even the installation of metallic bars for added support. An internal optical system is also in place inside the tower. This monitoring system consists of sensors which record data about variables such as horizontal-point movement, wind, and temperature. These measurements are recorded every 4 hours, but can be taken every 4 minutes, if needed.
With all of the push and pull on the Leaning Tower of Pisa, it's a miracle that it hasn't toppled over. Wind, weight, ground, and general structural weakness are all major factors for Pisa's most famous landmark.
Why not enjoy La Torre Pendente di Pisa while it still stands? Let's scale this remarkable bell tower as it hovers miraculously over its floor mats of clay and sand. Aren't you relieved that you don't have 200 years of work to do?
Next Stop…Walk Like an Egyptian
Resources
http://torre.duomo.pisa.it/towersposters/english_version/
http://en.wikipedia.org/wiki/Leaning_tower_of_pisa
http://travel.howstuffworks.com/leaning-tower-of-pisa-landmark.htm
Re: Pisa: We All Need Someone To Lean On
09/06/2007 11:15 AM
http://en.wikipedia.org/wiki/Chesterfield#History shows another structure in a similar state of distress. Chesterfield's church spire is further out-of-plumb than the Pisa tower, though its stability is less in question.
Welcome to Chesterfield, in Derbyshire, England!
09/18/2007 2:58 PM
It must be a Tony Benn thing. I once phoned the commons to canvas opinion on something, and he was the only one to answer his own phone personally. I ended up with the impression that he was a very nice guy (even though I think of him as 'odd') after a very convivial and nice chat. The one who has 'something of the night' about him is actually very nice face-to-face as well.
