Hemmings Motor News Blog Blog
Previous in Blog: Like a Rainbow in the Dark   Next in Blog: California Coastal Commission Signals Its Intent to End OHV Use at Pismo Beach Entirely
9 comments
Affordable Performance – the 2001-’04 Chevrolet Corvette Z06
Posted July 01, 2019 1:00 PM by dstrohl
Pathfinder Tags: chevrolet corvette history
Speed costs money,” the old saying goes, “so how fast do you want to spend?” There are exceptions to this rule, and one notable example is the C5 Chevrolet Corvette Z06, produced for the 2001-’04 model years. Given their performance potential, prices are (relatively) low today, but don’t expect that to be the case much longer.
As the Corvette faithful know, the Z06 name first appeared in 1963, attached to a package designed to turn the then-new Sting Ray coupe into an SCCA contender. Initially available only on split-window coupes, the Z06 package required the fuel-injected, 327-cu.in. L84 V-8, rated at 360 horsepower, with the M20 four-speed transmission. Checking the box next to the RPO Z06 option gave the buyer a 20-percent larger front anti-roll bar; vacuum brake booster; dual-circuit master cylinder; sintered metal brake shoes; 11.2-inch finned aluminum brake drums with front brake cooling ducts and vented backing plates; firmer dampers and stiffer springs; and a Positraction rear with 3.70:1 gearing.
Too young to be a true classic, but definitely an OG.
Re: Affordable Performance – the 2001-’04 Chevrolet Corvette Z06
07/01/2019 6:43 PM
07/02/2019 9:04 AM
389HP 390 ft-lbs torque and 7 speed paddle shift transmission
with a back seat! 2008 Mercedes CLK550 AMG package.
MikeMack747
07/02/2019 2:19 PM
2012 Hyundai Equus 8-speed ultimate luxury and 429hp...cheap
https://www.carfax.com/Used-2012-Hyundai-Equus_z21665
07/02/2019 9:46 AM
Aluminum brake drums? That sounds somewhat unconventional.
07/02/2019 10:14 AM
Haha yeah....
..."The center and braking surface is cast iron, and the outer ring is cast aluminum. "...
07/03/2019 11:28 AM
But, are those really drum brakes with shoes ? Seems odd in a 'modern' vehicle. My Suburban's parking brakes are small drum brakes (top hat style) inside the rear rotors.
But I do understand that drum brakes have potentially much better stopping power than disks because of the increased friction surface area. Most semi-trailer brakes are still drums. And, I guess the finned aluminum gets rid of the heat better than typical vented rotors to mitigate the heat issue that plagued old-school drum brakes under hard use.
07/03/2019 4:21 PM
Well that's a 1963 corvette the're talking about, not the '01-04...
..."1965 was both the first year for all wheel disc brakes and the last year for the fuel injected engine. The two magic performance features would not appear together until 17 years later in the 1982 Corvette."...
07/08/2019 10:58 PM
How did they accomplish this without fear of corrosion from the dissimilar metals?
07/11/2019 12:36 PM
The cast iron surface appears to be pressed in, and if left in a damp environment they would corrode...
Ref link...
Brave Sir Robin (2); MikeMack747 (1); SolarEagle (5); SWB123 (1)
