Hemmings Motor News Blog Blog
Previous in Blog: Selling LUV, Chevrolet Style   Next in Blog: Five Tips to Keep Your Classic Car From Being Stolen
6 comments
Ajax Tires – Guaranteed for 5,000 Miles!
Posted August 06, 2019 9:00 AM by dstrohl
Pathfinder Tags: classic auto mileage tires
Can you imagine buying tires for your car knowing that they are only guaranteed to last 5,000 miles? Considering that the average American motorist drives 12,000 to 15,000 miles every year, that means your Ajax tires would only have lasted 2.4 to 3 months, maybe a half-year if you were lucky. In 1907, Ajax Tires was rightly proud to make that bold claim, after all, back then it probably took a motorist a year or two (if not more) to accumulate 5,000 miles.
Back in November 1974, I bought my first set of new tires. The month previous I bought my first car, a 1968 Triumph Spitfire MKIII and two of its tires were bald. I was only able to afford two new tires, so for a mere $34 each, I bought a pair of Pirelli Cinturato CN 54s. They were guaranteed to last something like 50,000 miles, which was unheard of back then. These “steel belted radials” were cutting-edge tire designs at the time, along with the high-performance Cinturato CN 36s, and oh boy did they help transform my Spitfire’s handling.
It goes to show, dependability is relative.
Re: Ajax Tires – Guaranteed for 5,000 Miles!
08/06/2019 11:13 AM
Yeah but what did the roads look like in 1907...?
You've got to compare apples to apples, so off-road tires guaranteed 5,000 miles? Good luck on that....
These off-road tires are not guaranteed for off-road use...haha
4-YEAR MANUFACTURER WARRANTY
The 4-Year Manufacturer Warranty is a non-prorated replacement for any manufacturing defects in material and workmanship under normal and intended use. Non-intended uses include racing, off-road use, or competition use. If a manufacturing defect in material or
workmanship occurs, the tire will be replaced at no charge, on a non-prorated basis to the consumer.
CONDITIONS AND EXCLUSIONS
Fury Off-Road tire warranties are limited to the original purchaser and the original vehicle on which they are installed and such warranties and guarantees not assignable to subsequent purchasers or vehicles. All warranties and guarantees by Fury tires are only applicable in the United States, Canada, or Puerto Rico; any tires used or equipped on a vehicle registered or operated outside the U.S., Canada or Puerto Rico are not covered by this warranty.
The following is not covered by the Limited Warranty:
• Tire branded or marked “blem,” “Non-Adjustable (N/A),” or previously adjusted. Failure, damage or irregular wear due to:
• Road hazards (i.e. punctures, cuts, snags, bruises, impact breaks, etc.), wreck or collision;
• Fire, accident or vandalism; • Mechanical condition of vehicle, including misalignment, wheel imbalance, faulty
shock s or brakes;
• Misapplication of tire or use of improper inner tube;
• Alteration of the tire, or addition of alien material.
• Use of tire chains, tire spinning, racing, off-road use, or other competitive activities.
• Your vehicle has staggered tire fitments.
• Costs of mounting and balance service.
• Costs related to tire pressure monitoring systems.
• Costs related to shipping and transportation of the tire.
• Loss of time or use, inconvenience, or any incidental or consequential damages.
• Improper use or operation including, but not limited to: improper tire and vehicle maintenance, run flat or run with severe under inflation, misuse, abuse, accident fire or chemical corrosion, under inflation, overloading, over deflection, or failure to follow recommended rot ation practices.
• Improper installation, improper mounting or demounting, misapplication, improper repairs, wheel misalignment, or imbalance in the tire/wheel assembly.
• Your tire size, load and speed rating do not match the tire specifications outlined in
your vehicle owner’s manual.
• Tires with the Department of Transportation (DOT) number removed or rendered illegible; tires must bear the DOT prescribed tire identification numbers.
• Ride complaints after the first 1/32nd of tread wear or due to damaged wheels or any
vehicle condition
Fury Off-Road Tires does not warrant any work performed by the dealer, including, but not limited to, their selection, fitment, mounting and balancing, inspection, or repair of any tire
https://www.furytires.com/our-warranty
That 5,000 mile guarantee is looking pretty good now eh?
08/07/2019 8:32 AM
Well based on technology and miles driven in those days it may have been a good deal and as has been pointed out the ROADS were cow paths.
Back to the Triumph, you put on two radial tires what were on the other axle? Bias? belted? I question how the handling appeared to be improved.
08/07/2019 10:58 AM
Well it probably only cost about $5 for a whole set of tires back then....so, yeah I'd say it was a very good deal...probably threw in a patch kit ta boot....
08/07/2019 11:10 AM
According to my parents and grand parents every one that got behind the wheel knew how to crank the car to start, jack up the car and change or patch a tire. Now days just ask someone to drive a standard????
08/08/2019 9:56 AM
Yep, there weren't no triple A and if you car got towed it was quite possibly by a team of horses.
08/07/2019 10:14 AM
You don't get many miles out of really sticky track tires.
MikeMack747
MikeMack747 (1); rashavarek (1); roy hammy (2); SolarEagle (2)
