Hemmings Motor News Blog Blog
Previous in Blog: Could This Have Been the First Chevrolet Corvair Powered by a Small-Block V-8?   Next in Blog: Which Car from It's a Mad, Mad, Mad, Mad World Would You Choose for Your Dream Garage? (Part 3)
5 comments
More than a Fancy Check Engine Light, OBD-II has Transformed Vehicle Repair and Maintenance
Posted August 02, 2021 8:46 AM by dstrohl
Right about at knee level, typically tucked away so you'd never see it unless you needed to, sits the most powerful tool modern cars have. Sure, when the U.S. Environmental Protection Agency mandated that all cars sold in the U.S. come with an OBD-II connector starting 25 years ago, it only did so to ensure that all of a vehicle's mandated emissions equipment worked properly, but in the quarter-century since, OBD-II has become indispensable for any enthusiast who wants to get the most out of a car.
As its name suggests, OBD-II is not the first on-board diagnostic system that automakers implemented. Fifteen years prior to the 1996 rollout of OBD-II, GM introduced its own on-board diagnostics predecessor - Assembly Line Communications Link (later renamed Assembly Line Diagnostic Link) - as part of its Computer Controlled Catalytic Converter emissions system (later renamed Computer Command Control).
Through the Eighties, engine management systems became more complex and more connected to other parts of the car. Meanwhile, standardization among carmakers remained nonexistent, making it difficult for states - particularly California - to switch from tailpipe emissions testing to testing programs that make use of the on-board diagnostics systems. So in 1990, when Congress set about updating the Clean Air Act, it included an amendment outlining what would become OBD-II.
Keep reading...
Re: More than a Fancy Check Engine Light, OBD-II has Transformed Vehicle Repair and Maintenance
08/02/2021 3:53 PM
It's definitely worthwhile buying an OBD-II scanner for the toolbox. If you don't have one, a lot of parts stores will scan it for you.
Good Answers: 54
08/09/2021 2:15 AM
It's a must!
If you let your battery go too low, the computer will need to clear monitors, before a smog test can be performed. Each manufacturer has it's own set of rules to clear the monitors. They call these "drive cycles" and some are very hard to clear. I've found that Honda is the easiest for me. My Honda drive cycle is to idle the car for a few minutes, then take off like normal until I get to the freeway. I accelerate like normal, then get to 50-55 mph and hold it there until I'm on the other end of town (5 miles or so), then I take the exit ramp to the other freeway (the one that was never built) and I lift throttle and let the car coast - I turn to the first exit on the right, still coasting and I let the car coast up hill to the light - must be under 20 mph. I turn right, get to the next street and pull to the side and park. I shut the car off, then turn it on. All the monitors will be clear, except for evap, which doesn't need to be clear to do a smog test in CA. If a monitor doesn't clear, I check the code (sometimes just a stored code, but not something that will trigger the CEL). I then have some work to do - most times it's a bad O2 sensor, but it could be plugs, coils, sensors or a mechanical problem with the motor or transmission. Also, some cars have sensors in the exhaust to check if an exhaust valve is open or closed - Dodge Charger/Challenger is known to have this. If the valve is bad or the sensor is out, a CEL is thrown and the repair can be expensive!
A lot of words to say that Rixter is right - an OBDII scan tool is a must for everyone. And they're so cheap now, there's no excuse not to have one.
08/09/2021 2:47 PM
A loose gas cap will mess it up also...
Good Answers: 54
08/09/2021 11:45 PM
Or a defective one!
Good Answers: 54
08/09/2021 11:48 PM
The evap test is suppose to take care of loose gas caps. It only runs between 1/4 and 3/4 tank (hint, hint). Since our state will allow a car to pass without the evap monitor clearing, and all the monitors will clear if the smog systems are working and the motor is sound, then someone could run a car outside of the evap test range to make all the other monitors clear.
However, as soon as the fuel tank is in the right range, the CEL will come back on, though the smog test would've been done and a certificate issued. You have two years to remedy the problem, or you just do the same in two years.
