Hemmings Motor News Blog Blog
Previous in Blog: Which Insect-Named Automobile Would You Choose for Your Dream Garage?   Next in Blog: Long Before the Mini, Marmon-Herrington's Transverse-Engine Front-Wheel-Drive Vans Made the Rounds in the US
Video: Building Your Own Tools Takes DIY to the Second Power
Posted June 20, 2022 8:59 AM by dstrohl
Pathfinder Tags: car maintenance Tools
Any do-it-yourself (DIY) project takes the right tools to accomplish, and auto restoration and modification require very specific tools — many of which are expensive (or, on the flip side, too cheap), bulky, ineffective or otherwise not well-suited to the gearhead looking to build or restore a car at home. Unsurprisingly, then, plenty of DIYers have taken to building their own tools tailored to their needs and budget. This is part of a tradition going back to the Mechanix Illustrated and Popular Mechanics days, except these days DIYers post their projects to YouTube. Let's take a look at a few for inspiration.
Perhaps the most common DIY tool build out there is the sheetmetal brake, if only because it's simple, it doesn't require many other tools to create, and it produces high-quality results for the amount of effort put into it. Bob at I Like to Make Stuff built a relatively straightforward brake that can be clamped to a workbench instead of bolted to a stand that constantly gets in the way. He explains in easy-to-understand terms the how and the why of putting it together. Another good one is Colin Furze's, which he mounted inset to his workbench, and there are bigger and more extreme DIY brake projects out there worth checking out.
If this is your bag of cats, you might have heard by now that it's possible to build your own stick welder from microwave oven parts. This is true, and again, there are plenty of videos out there showing just how to do that, though don't try to attempt any high-voltage projects like these without knowing what you're doing. Rather than build a case out of wood, as this guy did, you might want to consider bending some sheetmetal using your DIY metal brake.
View more videos like this.
Re: Video: Building Your Own Tools Takes DIY to the Second Power
06/20/2022 11:27 PM
I made a similar metal brake with hinges also. Mine clamps into a vise. I just use 1 or 2 crescent wrenches as the handles.
