Hemmings Motor News Blog Blog
Previous in Blog: Life Hacks for Gearheads   Next in Blog: Dodge Redefines EVs and Muscle Cars with its All-Electric Dodge Charger Daytona SRT Concept
The Challenge: Swap a Turbocharged V-8 into a Corvair
Posted August 23, 2022 5:00 AM by dstrohl
Pathfinder Tags: Corvair restoration
There are, certainly, easier ways to build a mid-engine V-8 Corvair.
Slide in a Toronado's UPP, for instance, or buy an off-the-shelf aftermarket transaxle to fit your preferred V-8; maybe you can figure out some shade tree mechanic solutions for retaining the Corvair transaxle. They all require some amount of fabrication, but then there's John Reynolds's approach with his 1967 Corvair, which requires substantial re-engineering of everything aft of the floorpan, but seems to be worth it in terms of the drivetrain choice: a transverse-mount LS4 from a 2006 Chevrolet Impala mated to a 4T80e from a 1996 Cadillac Deville, components he describes as plenty stout but often overlooked and thus less expensive. And then he decided to turbocharge the LS4.
Reynolds has been at it for a couple of years and has documented everything he's had to do to make the combination work over more than a dozen videos, with more to come. We've included a few highlights here, with the rest collected in a playlist on his channel.
Or watch more videos here.
