Chemical Manufacturing Blog
The Chemical Manufacturing Blog is the place for conversation and discussion about process equipment and control, biotech & environmental, specialty chemicals and nano-engineering. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: ACC Defines Responsible Care®   Next in Blog: Self Cleaning Coatings
4 comments
MTBF Blues
Posted September 12, 2007 10:24 AM by Steve Melito
Equipment failures can be catastrophic. To minimize downtime, you need to properly specify, install, and maintain your equipment and processes. Or, you can spend large amounts of money afterwards to restore your operation. Reliability studies show that about 68% of known failure modes are a result of infant mortality. In planning a new process, how do you determine what amount of downtime can be tolerated to achieve a balance between risk and expense?
The preceding article is a "sneak peek" from Chemical Manufacturing, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Chemical Manufacturing today.
Re: MTBF Blues
09/12/2007 10:15 PM
I will not say that I have the exact answer to your question, but I think that may be this book can help. To be honest I think the amount of downtime that can be tolerated will depend on a lot of parameters. Please go ahead and see if this book found in the Knovel library can help. Here is the link
http://knovel.com/knovel2/Toc.jsp?BookID=1470
Re: MTBF Blues
09/13/2007 10:44 AM
Moose:
I don't know how much of my old experience with military control systems can be transferred to today's users of chemical processing equipment, but, for that equipment, at that time, the first requirement was to DESIGN to a predetermined MTBF (Mean Time Between Failures). The requirement began at the contract phase and was carefully tracked in the field. MIL parts were specified to provide predetermined failure rates and purchased at the reliability level required to meet the contract.
Premature failures (Infant Mortality) were induced by rigorous environmental screening prior to shipment and were NOT a part of MTBF. Vibration and thermal cycling were mainstays.
Any indication of a high initial failure rate in the field indicated inadequate factory screening at some level. For products such as fighter engine mounted electronic controls, the analysis and screening were followed by MTBF tracking and FMEAs (Failure Mode And Effects Analysis) for certain failures. This all led to identification of the "Root Cause" for those failures and definition of corrective action.
If all of the foregoing actions were conducted correctly, there were few accident investigations, the ultimate goal.
DickL
Good Answers: 7
Re: MTBF Blues
09/13/2007 11:29 AM
Those are the same methods in the CPE (Chemical Process Industries).
One additional method is to determine the "class of quality" during the engineering stage. This is where you would ask questions about redundancy, in line spares, if the What level of failure or repairs is acceptable.
Is it OK to have to shutdown and clear the operating unit to repair a seal failure?
The PHA (Process Hazards Analysis) for those plants that are covered under OSHA Process Safety Management (29CFR1910-119) does similar review.
Re: MTBF Blues
09/13/2007 8:16 PM
It may slightly off topic for your letter but the MTBF comment caught my eye. I agree and I've just introduced a system for providing this type of information for rotating machines. It is extremely important for those concerned about reliability and reducing cost in systems using rotating machines-motors, pumps, HVAC, compressors etc If the topic is of interest you can check it out on www.bearinglifeguard.com Vibes
Anonymous Poster (1); Carine (1); DickL (1); Paddler (1)
