Previous in Blog: Future Energy Sources 5.0 Reduction of Energy Demand Through Population Limitation   Next in Blog: Future Energy Sources 7.0 Superconductors
4 comments
New downhole pump: Offers expanded technologies?
Posted September 21, 2007 2:07 PM by JBAvants
Pathfinder Tags: downhole pump petroleum
First PetroTechTalk Blog — ever! My name is J.B. Avants. I am editor of PennWell Petroleum's Oil, Gas & Petrochem Equipment, a monthly all-products-and-services print and online media. Take a look at this development and let me and your fellow oilfield associates know what you think:
Recently Texas-based TexJet introduced a new downhole pump as a complete lift system. It's engineered to employ a well's natural energy with gas injection to create natural flow.
Because I am an "editor" and not an "engineer," I'm interested in your response and reaction to this development.
Would this no-moving-parts / gas injeciton design and technology be applicable to pumps used in refining, gas processing, natural gas operations? It would not have to be limited to downhole operations only, would it?
With oil now consistently "bumping" $80/bbl — there's never been a better time to envision broader applications for this type technology. Let me know your thoughts!
Re: New downhole pump: Offers expanded technologies?
09/22/2007 7:47 AM
Welcome aboard, our niche is growing every day.
Working with Nationals and Internationals as an auditor, expeditor, inspector in mostly vendor surveillance, I see more work than I have in 35 years of doing this, not to mention all of the new Power Plants and Retrofts coming up.
With Steel Service Centers having trouble right now keeping stock on hand and at times a backlog in delivery of even small off the shelf items like flanges how will we supply the material, not to mention the crafts necessary to complete all of the planned projects.
For the record and to inform all of our cohorts in crime on C4, please generate a list of the National and International projects coming up.
I just finished Camisea Propane Project for Pisco, Peru and now starting an assignment for SAMIR in Morroco.
Thanks for a place to expound and ask questions.
09/22/2007 8:38 PM
"Recently Texas-based TexJet introduced a new downhole pump as a complete lift system. It's engineered to employ a well's natural energy with gas injection to create natural flow."
Just goes to prove there is nothing new under the sun. It is a glorified version of an aquarium bubble pump used to pump water and sediment off the top of the bottom sand to a filter above the top of the water for return to the aquarium.
A great adaptation of an old idea!
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
Good Answers: 7
Re: New down-hole pump: Offers expanded technologies?
09/25/2007 12:31 AM
Hi, J.B. Avants, its seems easier to blow than suck. Bare with me, try and pull a vacuum as apposed to creating 5000 psi. You can only go negative, max 32 psi. after that everything starts to collapse. More than that, you start to suck the atmosphere out of the sky and the air out of the liquid you are trying to pump (vapour pressure). Pumps do not like to pump air, only fans do! So in order to get oil oil out, over 150 feet, you need a down hole pump or artificial atmosphere to create enough flow to a pump so it can lift the oil to the surface. Liquid gas is a good one. Pump, lets say Butane @ plus 3 Degrees C and by the time it hits the warm oil, it will expand by 600 to 1600%. Lots of push for a little bit of effort. Easier on seals and motors. Does this make sense??
Could be worse, it could be me. :)
Popular Science - Evolution - New Member
10/10/2007 12:26 PM
Concept is nothing new, 'Air Lift Pumps' exist for a long.
TexJet has appropriated this type for oil well applications...
A picture worth thousand words: needless to say if it is animated.
mayt2u (1); qaqcpipeman (1); Stirling Stan (1); yesyen (1)
