Aerospace Blog Blog
Aerospace Blog
Previous in Blog: How To Spend a Trillion Dollars   Next in Blog: Your Cosmic Questions Answered (Part 2)
12 comments
Your Cosmic Questions Answered (Part 1)
Posted April 24, 2008 6:00 AM by M&M_aero
Most of us can remember the time in elementary school when we first studied outer space. For me, it was in the second grade. My teacher showed us a movie about our solar system. Then we talked about what we had learned. My teacher taught us about the nine planets (yes, Pluto was a planet back then), the Moon, the Sun, the asteroid belt, comets, and so much more. That month of science class was one of the most exciting I've ever had. In fact, it started me on the long path I'm on today to earning my bachelor's degree in aerospace engineering.
Now think back to that period in your own life. Were there questions that never got answered? Things you've wondered about for years? Or, maybe you'd just like to learn something new that you've never even thought about! Here are some confounding cosmic questions and their not so confounding answers.
Why isn't the North Star the brightest star?
Known also as Polaris, the North Star may be the most important star in the northern hemisphere; however, it ranks 49th in terms of brightness and is directly overhead for very few viewers. Polaris wasn't named the North Star because of its brightness, but because of its proximity to the north celestial pole, the pivot point directly in the north around which the stars go daily ( at least when viewed from the northern hemisphere). So, when you go out looking for the North Star, be sure to locate it by using the Big and Little Dippers as reference points - not by brightness. Otherwise, you may point out Vega, the 5th brightest star in the sky and one that is directly overhead for most people.
Why don't people talk about a "South Star"?
The answer to this question is simple there isn't one that's easily observable! The closest candidate is very small and faint. Called Sigma Octantis, it's is located in the constellation of Octans, the Octant. The South Star is only 1/25th as bright as the North Star. Therefore, whereas people in the northern hemisphere rely upon the North Star, people who live in the southern hemisphere rely upon Crux, the Southern Cross, because its longer bar points toward the South Pole.
Editors Note: Part 2 of this blog will run next week
CR4 Aerospace Blog
Re: Your Cosmic Questions Answered (Part 1)
04/24/2008 4:13 PM
I always wanted to understand women.
Sorry. Couldn't resist.
Engineering Fields - Mechanical Engineering - I am here to help!!
04/25/2008 6:08 AM
Can u please tell me, why we see only one side of the moon? I tried so much but couldn't find an easily understabdable answer.
Good Answers: 70
04/25/2008 10:40 AM
My best guess is that the moon is not perfectly symmetrical around its axis. The near side (the one that we see) is slightly denser than the far side. Because of the tidal forces (gravity) between the earth and the moon, this heavier side of the moon has settled into a position as close the the earth as possible. It's kind of like rolling a marble inside a bowl. Eventually it will come to rest at the bottom, the spot closest to the earth.
Actually the moon may never have had much rotation (other than the approx one revolution per month needed to keep the same side always facing the earth), and may instead have formed under the influence of the earth-moon tidal forces. One current theory is that it was formed by the accretion of the partially molten debris ejected into space by a collision between the earth and another small planet. As the debris (think lava) was coalescing, tidal forces would have favored the denser materials clustering on the near earth side of the blob. In addition the tidal forces would have caused a tidal bulge on the near earth side as well. Now that the moon has solidified, this asymmetry has 'locked' the moon into a position where the same denser side always faces the earth.
04/25/2008 5:04 PM
It's not so much a density issue, but tidal coupling and the nearly identical periods of the Moon's rotation and revolution in orbit (except for small fluctuations, both are about 27.3 days) cause us to see essentially the same side of the moon. We actually observe about 55% of the entire surface. Hope this is easier to comprehend, but if not, http://www.fearofphysics.com/SunMoon/sunmoon1.html should help visualize it.
Good Answers: 70
04/25/2008 5:50 PM
You are right that it is tidal coupling, which results in the almost identical orbital and rotational periods. I was merely trying to speculate as to the cause of the tidal coupling, which is why I suggested that the moon's mass is asymmetric with respect to it's axis, giving it a heavy side and a light side. The heavy side would be the one facing the largest local source of gravity, which is us.
Good Answers: 204
04/25/2008 6:48 PM
If you read Zecharia Sitchin and the Sumerian cosmology (the Earth Chronicles series), the clay tablets tell a story told to us by the 'gods', and was repeated annualy in the spring festival, in a story known as the "Enuma Elish" (In The Beginning")
It says that the planet Earth used to be a much larger planet, mostly water. It had a large moon that was nearly a planet size itself. A "Wanderer" came in from outerspace, and it had 4 moons of its own. (East Wind, West Wind, North Wind, South Wind) which smashed consecutively into the mother planet, and kicked the mother planet and her moon into our current orbit. Most of the water was splashed out to mars, jupiter neptune. This also formed the Hammered Bracelet (asteroid belt) and the comets, and of course, smacked hell with our moon. (craters) The pacific ocean is the healed over scar of the missing half of our planet.
It would seem to follow that the moon, however it was originally formed, has an erratic orbit because of the disturbance to it's orbit 65000 years ago (which terminated the Jurassic period of course)
04/25/2008 10:58 PM
Intresting,
I've heard of Sitchen's works (mostly from the Art Bell show) but have not gotten around to locating any of it to read (so many words, so little time). It sounds similar to a book I read a short time ago called "The Biblical Flood and the Ice Epoch". It also depends on interpretation of Sumerian tablets. It, like a lot of other theories is largely unsupported and unsupportable, no matter how reasonable it sounds. That, at least, is my take on the matter.
04/28/2008 10:00 AM
Too bad I don't read Sumerian - I'm not sure I'd trust a translation...
Good Answers: 204
04/25/2008 12:24 PM
How did pre-einstein astronomers and physicists think about red shift/ blue shift of light from the stars? how did they explain it, in terms of aether?
Good Answers: 70
04/25/2008 2:23 PM
I don't think the issue ever came up, because before we had Einstein's theories, we also didn't have any telescope/spectrometer systems around that were sensitive enough for this type of work. By the time Hubble made his discoveries of red and blue shift (remember he never explicitly claimed this meant the universe was expanding), Einstein's main contributions were already well understood.
04/25/2008 5:51 PM
They didn't know about it. I didn't know about it aether. He He
04/28/2008 9:59 AM
I see you've been into the laughing gas again...
Anonymous Hero (1); chrisg288 (2); EnviroMan (3); johnfotl (3); pc (1); Shadetree (1); StandardsGuy (1)
You might be interested in: Compasses, Flat Cables, Grounding Straps
