TechnoTourist’s Engineering Expeditions Blog
Want to travel the world, but don't have time to leave the office? TechnoTourist is here to save the day! Tag along while TechnoTourist visits famous engineering feats around the world. TechnoTourist will also investigate fascinating technologies that help to preserve and discover incredible travel locations. Maybe you could use TechnoTourist's insights to help you plan your next travel itinerary, or escape from the stresses of everyday life!
Previous in Blog: TechnoTourist Visits the Kennedy Space Center   Next in Blog: Roman Baths: Splish Splash! Taking Off to Bath, England
6 comments
Falkirk Wheel: You Spin Me Right Round, Baby
Posted May 27, 2008 6:00 AM by TechnoTourist
Right round like a boat lift, baby! Dead or Alive's hit song, "You Spin Me Round", takes a different tune here in Falkirk, Scotland, Mukker (friend). After our adventures riding the Apollo Gantry at the Kennedy Space Center, I couldn't help but venture to Falkirk, to ride on the world's one and only rotating boat lift.
Are you wondering why this boat lift needs to rotate, Mukker? Let me answer your question. The Falkirk Wheel is a part of the Millennium Link project to restore navigability in Scotland. The Falkirk Wheel fulfills this objective because its sole purpose is to connect the Forth and Clyde Canal with the Union Canal. This connection would not be possible without a rotating boat lift since the Union Canal is 35 meters above the Forth and Clyde Canal.
Rotation alone makes the Falkirk Wheel quite an engineering feat. Each gondola contains 300 tons of water; therefore, each lift the Falkirk Wheel supports 600 tons of water. But that's not all. The Falkirk Wheel is the height of eight double-decker buses stacked on top of each other, and was constructed from over 1100 tons of steel. This steel is held together by over 15,000 bolts to ensure that the structure is as sturdy and robust as possible. What's more is that these bolts were hand-tightened!
The one of a kind Falkirk Wheel is most impressive! But did you know that eight boats at a time can be rotated on the Falkirk Wheel!
The hour long boat tour was fun and informative, but the journey isn't over! "All I know is that to me, you look like you're lots of fun," Mukker, so let's head on this footpath to visit the Rough Castle Roman Fort, which still has preserved portions of the Antonine Wall. Watch out, here we come!
Next Stop: Splish Splash! Taking Off to Bath, England
References:
http://www.falkirk-wheel.com/
http://www.linguanaut.com/english_scots.htm
http://www.undiscoveredscotland.co.uk/falkirk/falkirkwheel/index.html
http://www.thefalkirkwheel.co.uk/about/engineering.html
http://www.butterleyengineering.com/structures/structures2.htm
http://www.brianmicklethwait.com/images/uploads/FalkirkWheel2.jpg
Re: Falkirk Wheel: You Spin Me Right Round, Baby
05/28/2008 6:55 AM
Sorry but you are wrong, the Anderton boat lift on the Stafordshire Trent canal was built many years ago, this was the first original boat lift in the world, and it lifts boats much hire that the Falkirk wheel!!!!!!!!!!!!!!!!!!!!
Spencer.
05/28/2008 12:41 PM
Thanks for your comment. You are correct, the Anderton Boat Lift was built far before the Falkirk Boat Lift. However, the Falkirk Boat Lift is unique because it is rotating.
"Even if you're on the right track, you'll get run over if you just sit there." - Will Rogers
05/30/2008 5:17 AM
Hi TechnoTourist,
Yes I have seen the Falkirk wheel on a number of ocasions, and as you said it is unique because it is a rotating lift.
I have also seen many incline-lifts on various European canals, the one in France raises the boats 21 vertical meters, while the one in Latvia lifts the boats 47 vertical meters over a distance of 310 meteres.
Spencer.
12/11/2008 4:33 AM
whatever mate thats all good but the Falkirk wheel is amazing and that one isnt
05/30/2008 7:51 AM
Meanwhile in the USA they can't even build a coart to coast high speed rail system. Or descent rail system that moves north to south. If I want to go to Fla from Tennessee by Amtrack I must go to South Carloina then catch the North bound train to Washington D.C then chance to the South Bound tain to Miami. But I can stop in South Carloina if I get on the right one. Only a few stop there.
06/10/2008 7:51 AM
<...This connection would not be possible without a rotating boat lift [in the space available] since the Union Canal is 35 meters above the Forth and Clyde Canal...>
Consider locks. At, say, 2m rise per lock, around 17 of them would be needed, and a length of hillside of somewhere over 1.5km. At 15 minutes per lock (and that's going some!) it would take the best part of a day to 'do' the flight ['flight' is a term that means a group of locks].
So the Fakirk wheel is a both a time- and space-saver, as well as an European Icon.
Nice blog.
Anonymous Poster (1); dadw5boys (1); PWSlack (1); Scapolie (2); TechnoTourist (1)
You might be interested in: Lift Tables, Lift Stations
