The F-35 Lightning II will
come in three different variants, each with a specific purpose. The F-35A will be the version used by the US
Air Force (USAF) to replace the F-16 Fighting Falcon and - by 2028 the A-10
Thunderbolt. is the F-35A is a
conventional takeoff and landing (CTOL) fighter, and will be the lightest
variant. It will also be the only F-35 with
an internally- mounted cannon, thus bolstering its stealth capabilities. Already,
foreign customers are lining up. Israel plans to buy over 100 F-35As
to replace its fleet of F-16s at an estimated cost of over $5 billion.
The F-35B is the variant that
will be used by the U.S. Marine Corps (USMC) to replace the Harrier Jump Jet
and the F/A 18 Hornet. The F-35B is a
short takeoff and vertical landing (STOVL) aircraft, meaning that it has hovering
capabilities. To accomplish this, the
F-35B uses vertical-thrust vectoring on the main engine in the rear, and a lift
fan near the front of aircraft. While
using this vertical-lift system, roll stability is maintained by channeling
pressurized air from the center-lift fan through the wings to the wingtips and
ejected out thrust nozzles called Roll Posts.
For the U.S. Navy (USN), the
F-35C is the carrier variant of the aircraft.
This plane has larger control surfaces for added control during slow
flight. The landing gear on the F-35 C
is more durable due to the added stress of carrier landings. Also, the wings can fold up in order to save
space on the carrier deck.
The B and C variants will be
available starting in 2012, and the A variant in 2013.
Editor's Note: Click here for
Part 1 of this two-part series.
