Drip Trap, "the friendly oil absorbent," is a flat brick of compressed
corn leaves and stalks that claims to never spill or leak or track oil
when walked on. And it's recycling what would normally be a waste
byproduct from farming the corn. Installation: Slide it under your car. Results: Your car leaks less! No, not really. That's just a really old
piece of cardboard (which has seen a couple oil changes) for comparison.
As advertised, the oil stays in the brick when you walk over it. Note,
however, that it's a brick instead of a mat. It's easy to trip over it
when the car's not parked over it. As for when you're done with it, the
packaging recommends disposing it as you would any waste oil.
Find out if Drip Trap really works.
Read the Whole Article
