Previous in Forum: Battery Bank Sizing   Next in Forum: Power Up LEDs
13 comments
CBCT Connection
03/21/2015 4:31 AM
Is it required to take neutral cable through CBCT along with RYB cable.
i think RYB is enough?ryt? if no correct me.
Pathfinder Tags: CBCT
Re: CBCT Connection
03/21/2015 6:10 AM
ryt.
Re: CBCT Connection
03/21/2015 7:33 AM
Re: CBCT Connection
03/21/2015 11:08 AM
ryb ?
Re: CBCT Connection
03/21/2015 12:11 PM
Three phases. Should be "cables". Neutral needed in case loads aren't exactly balanced.
Re: CBCT Connection
03/21/2015 12:14 PM
New Zealand - Member - Kiwi
Good Answers: 29
Re: CBCT Connection
03/21/2015 3:32 PM
The problem here is interpreting these TLAs and FLAs.
paulusgnome
Re: CBCT Connection
03/21/2015 7:19 PM
We haven't heard from Anonymous Hero yet, he's from FLA.
United Kingdom - Member - Not quite retired Member
Location: Up an araucaria araucana tree, South London, United Kingdom
Re: CBCT Connection
03/22/2015 5:40 AM
If there is a difference between the three phases, a neutral current will flow. There will be an imbalance in the RYB
The fourth, neutral cable must pass through the residual current detection. If there is then an earth fault, there will be an imbalance to operate the protection.
Re: CBCT Connection
03/22/2015 6:30 AM
Do you have access to your national wiring standard? If so, read it. If not, then why not?
Good moaning!
India - Member - New Member
Good Answers: 164
Re: CBCT Connection
03/22/2015 11:20 AM
All four conductors have to pass through the CBCT. You don't want unbalance to trip the ELCB. Only earth leakage. That will happen only if the vector sum of the entire current is zero normally. Any earth leakage will make the vector sum no longer zero, so the ELCB (or RCD/ RCBO) trip. This is the reason that it is called "Core-Balance-Current-Transformer"
Re: CBCT Connection
03/22/2015 2:55 PM
Not sure what a CBCT is (I doubt your working on dentistry scanners). Circuit breaker current transformer perhaps?
I don't know what type of electrical and grounding system you have so cannot say (they vary from country to country and even state to state).
Refer to your local Indian electrical standard and electrical codes of practice, the answer will be in there.
Re: CBCT Connection
03/23/2015 6:01 AM
A simple reply is:
if there is a neutral conductor (TPN or 4-wire supply) - Yes.
if there is no neutral conductor (TP or 3-wire supply) - No.
Any protective earth continuity conductor should be outside the CBCT
Re: CBCT Connection
03/23/2015 10:39 AM
Their are specific requirements in various electrical codes for switching the neutral. You probably need to consult with a local electrician who knows the local requirements. Most of the time you do not switch the neutral in most codes, but again codes vary. -- JHF
Register to Reply 13 comments
Brave Sir Robin (1); Circuit Breaker (1); Crabtree (1); Geoffrey36 (2); jack of all trades (1); JohnDG (2); kvsridhar (1); lyn (3); Paulusgnome (1)
