Previous in Forum: Fluorescent Behavior   Next in Forum: Protection of short line between power plant and substation
Heating nitinol rod using AC/DC power supply
07/11/2007 11:17 AM
I want to heat this nitinol SMA wire- rod ( 6.5mm diameter and 1ft long) up 80C using a AC/DC power supply.
the resistivity of the material is 76microhoms-cm
the problem is that the resistance is very very small so when i turn on the power supply, which by the way i'm using direct current 28VDC, the voltage is like 0.3 and the maximum amps I can get are 13 because then the pw starts heating and turns off. the max temperature i have reached is 42C but not on all the rod, only at the ends were the rod is connected to the power supply. I have left it for a long time to see if with time the rod heats but the only thing that happens is that the power supply gets really hot and goes down....
i was wondering what circuit or what can i do to increase the amps...
i have connected a resistor in series with the rod... but the resistor is the one that heats up heheh.. not the rod...
Re: heating nitinol rod using AC/DC power supply
07/11/2007 3:01 PM
You need to reduce the output voltage of the power supply you are using (the power supply is going into current limit which is probably not very good for it at all). The rest is simple ohms law (and a bit of trial and error to get the right power to give 80deg C). Try a lower voltage or variable voltage power supply (after you figure out what the value of resistance of the rod is).
Re: Heating nitinol rod using AC/DC power supply
07/12/2007 5:51 AM
Here's a trick I used to test circuit breakers one time. If you can obtain a current transformer (http://en.wikipedia.org/wiki/Current_transformer) you can energize the output coil with low voltage AC. Make a closed loop including the Nitinol wire pass through the core of the current transformer. If you figure out how much current you need, current transformers are usually rated as output voltage vs input current. Just reverse the relation.
07/12/2007 7:41 AM
One way to go about this is to use a lower impedance supply. You can heat the rod with DC, but the supply will cost more than heating it with AC. An arc welder supply or even a spotwelding transformer should do a good job. In any case, the supply you are using is not appropriate. Adding a resistor in series just increases the supply impedance and makes things worse.
