Previous in Forum: Will This Be Driving Your Car Soon?   Next in Forum: OMG It's Starting...... the Idiocracy!
Sound Cancelling Tech Taken to a New Level....?
03/25/2015 11:38 AM
"Boeing Patents Futuristic Force Field
..."[The system] may include a sensor for detecting a source of the shockwave and generating a detection signal, an arc generator in communication with the sensor and configured to receive the detection signal therefrom, and in response thereto create an electromagnetic arc to heat a selected region of the first fluid medium rapidly to create the second, transient medium, different from the first medium, interposed between the shockwave and the protected region such that the shockwave contacts the second, transient medium," the patent sort of explains.
Just how this arc force-field will work is left pretty open, but Boeing has submitted a few ideas, including using at least one of the following - "high intensity laser pulses, pellets forming a conductive ion trail, sacrificial conductors, projectiles trailing electrical wires or magnetic induction".
If the first medium is, as it probably would be, the air, the idea is that the arc generator would create a second medium different in density, temperature and composition, in this case by superheating the air, which could then reflect, refract, absorb or deflect at least part of the damaging shockwave."
http://www.forbes.com/sites/bridaineparnell/2015/03/25/boeing-patents-futuristic-force-field/
Re: Sound cancelling tech taken to a new level....?
03/25/2015 12:09 PM
So say we have a meteor going to strike, and we expect it to explode at Xk ft altitude, generating a shockwave similar, but even more powerful, to the one seen recently in Russia.....How would we deploy this shockwave cancelling device? Would we need to encircle the impact point with say three or more of these devices? Could we vaporize this meteor with a laser before it reached the point of explosion? Could we deflect the meteor at high altitude with this tech? ....or could we cause the point of explosion to be at a much higher altitude? Should every population center have these devices?...or just critical infrastructure?
" Published on Feb 17, 2013
Russian METEOR Shockwave filmed by security cam !!
The 55 foot wide rock, said by Nasa to have a mass of 10,000 tonnes, lit up the sky above the Urals region on Friday morning, causing shockwaves that injured 1,200 people and damaged thousands of homes in an event unprecedented in modern times.
Nasa estimated that the energy released as the meteor's disintigrated in the atmosphere was 500 kilotons, around 30 times the size of the nuclear bomb dropped on Hiroshima in 1945.
It entered the atmosphere at 44,000 miles per hour, taking 32.5 seconds to break up at an altitude of around 15 miles above the earth's surface.
The resulting explosion created a shockwave that blew out windows and set of car alarms in Chelyabinsk two and a half minutes later.
Divers were this morning searching the Chelyabinsk region's frozen Lake Chebarkul for a fragment of the meteorite."
https://www.youtube.com/watch?v=fMNVPRCzoxg
03/26/2015 10:17 AM
Could these waves be stacked to create a more powerful harmonic wave?
Good Answers: 16
Re: Sound Cancelling Tech Taken to a New Level....?
03/25/2015 10:44 PM
Secret pictures of early research into shock waves, force fields etc.
DY
03/26/2015 1:21 PM
It seems that the compensating source would have to be as strong as the shock wave and would cancel it out at only one location, and make it twice the amplitude at another location.
http://www.foxnews.com/tech/2015/03/26/sci-fi-cloaking-device-could-protect-soldiers-from-shock-waves/?intcmp=latestnews
Register to Reply 4 comments
Don from Oz (1); Rixter (1); SolarEagle (2)
