Previous in Forum: Need Help to Identify Shorting Components in Powersupply   Next in Forum: Needle Valve in Steam Line
Do 4-20ma Can Be Superimposed On RS-485 Cable
03/25/2015 12:54 PM
Do 4-20ma can be superimposed on RS-485 cable, I have seen a datasheet they are using a ultra-sonic multipath transmitter, the output signal is Rs-485 serial interface 4-20ma HART superimposed, do its possible, if possible how come 2 signals data can be retrived. the communication protocaol is Modbus RTU.
output signal: RS-485 serial interface
output reading: flow rate.
serial comm port: rs-232, rs-485
communication protocaol: modbus RTU
Re: do 4-20ma can be superimposed on RS-485 cable.
03/25/2015 1:09 PM
Instead of waiting, you could pick up the phone and talk it through with the equipment supplier, Mildred. It seems people are frightened to do that these days.
Good moaning!
03/25/2015 2:10 PM
Good Answers: 176
Re: Do 4-20ma Can Be Superimposed On RS-485 Cable
03/25/2015 2:49 PM
No, 4-20mA is not superimposed on the RS-485 line or vice versa.
There are multiple, separate, individual connections on this device.
One connection is 4-20mA HART (yes, HART is an FSK signal superimposed on the DC 4-20mA). Its connections will have a (+) and a (-).
A second connection is RS-232, which supports Modbus RTU. It will like have a Rx, Tx and a signal ground.
A third connection is RS-485, which supports Modbus RTU. It will likely have a connector with A, B and signal ground.
The 4-20mA does not mix with either the RS-232 or RS-485.
03/25/2015 3:52 PM
(4-20 )mA it is not superimposed on any RS(232/485)it is superimposed on (FSK) frequency shift keying to make up (HART communication protocol) if you want to communicate between (4-20mA.HART) device and your PLC(control) or p.c use on of these adapters converters FXA191 FXA193 FXA1195 via RS232/usb ports .to make a control orders regarding with
RS232 or RS485 in your flow rate they are for operation software program that comes on a disc and installed in your P.C it is just to monitor not to handle (4-20mA.HART).for read or write data.
good luck .
03/26/2015 12:13 AM
Tnks for your feedback frnds...
classic (1); Crabtree (1); Iris (1); mohsinhamid (1); Rixter (1)
