Previous in Forum: autocad mechanical2004 serial number   Next in Forum: INtools Software
AutoCAD 2007
07/11/2007 3:30 PM
I want to have menu buttons on the computer screen to shorten process of finding them though menu.
I have it done in AutoCAD 2004 easily.
2007 has something I cannot overcome.
Help!!!!!!!!!!!
apcco@verizon.net
Pathfinder Tags: AutoCAD 2007
Re: AutoCAD 2007
07/11/2007 4:04 PM
Yep, it's a bit more complicated than it used to be...
Go to: Tools > Customize > Interface
Under the "Customize" tab, expand the Menus list
Pick the command you want from the Command List, then Drag & Drop it into one of the menus listed under the Menus List (I hope that makes sense... )
If the command you select doesn't have an icon, you will have to create one.
In the properties area, select either "small image", or "large image". Click the "..." box and choose an icon you have previously made. Or, scroll thru the box of icons shown under "button image" and pick one from AutoCAD's database.
Hit "Ok" and you're set.
Hope that helps!
Re: AutoCAD 2007
07/12/2007 4:10 PM
Sorry it did not help.
Re: AutoCAD 2007
07/16/2007 4:11 PM
Ok, a step back then.
Right click in the toolbar area, but not on a toolbar. A menu of toolbars will appear. Pick the draw, modify, dimension, or any other toolbar you need.
You can customize these toolbars by using the method in my previous reply.
If this does not help, you will need to be more specific with what you are asking.
Re: AutoCAD 2007
07/17/2007 7:31 PM
I really appreciate your help, but it does not work.
More specifically I want to put TOLLPALETTES on the screen.
For example, icon of palette "extrude" or palettes of "3D Navigate Control Panel" and the like.
Thanks
Register to Reply 4 comments
