Previous in Forum: Water Flow Problems / Unbalanced System Injection Moulding Shop   Next in Forum: Hardness Measurement of Weld Tube
9 comments
Hypothesis Experiment
04/09/2015 7:33 AM
What mostly parameter is use to determine the hypothesis of a sample?
Re: Hypothesis Experiment
04/09/2015 7:45 AM
A sample does not have a hypothesis. It is the experimenter (the person doing the experiment) that has a hypothesis.
04/09/2015 7:47 AM
Hypothetically, none at all.
04/09/2015 12:43 PM
Good Answers: 97
04/09/2015 12:49 PM
The overall dimensions, to include the waist, inseam and length of the straps.
CRTL-Z
04/09/2015 2:47 PM
The two legs meet at a 90° angle and the hypotenuse is the longest side of the right triangle and is the side opposite the right angle.
Good Answers: 97
04/09/2015 2:52 PM
The right front vest pocket to be of dimensions to accomidate the standard hen dipped snuff can. Don't believe hen dipped snuff? Check under her wing.....
CRTL-Z
04/09/2015 3:53 PM
A sample of the responses so far would suggest that, hypothetically at least, this thread is going in random directions for want of parameters.
Good Answers: 97
04/09/2015 4:09 PM
Like rudderless ships passing in a fog. What is curious, is the fact that any reply, based on the question, has no hypothetical base for degree of point.
CRTL-Z
04/09/2015 4:20 PM
Your going to have to explain your question better and give us an example or two as it is rather unclear what you are asking for exactly.
Can you clarify please?
Register to Reply 9 comments
jack of all trades (1); Kilowatt0 (1); lyn (1); PWSlack (2); redfred (1); Unredundant (3)
