Previous in Forum: Impact Energy Formula Needed   Next in Forum: CNG Car - problems in performance
Surface Treatment: Nickel Plating Tubes
07/12/2007 4:45 AM
How to perform nickle(Ni) plating inside of a dia 35 mm tube.
What are the methods & what parameters required for Ni plating ?
How to check plating thickness inside of a tube?
Please help me getting this information or mail me at gurpreet@skhmetals.com
Re: surface treatment
07/12/2007 8:41 AM
Re: Surface Treatment: Nickel Plating Tubes
07/12/2007 4:05 PM
are you plating to acheive a low Ra, or do you desire some other properties of the Ni ?
for surface finish there might be other options.
Good Answers: 94
07/13/2007 4:49 AM
Have you looked at electroless nickel plating? http://www.corrosion-doctors.org/MetalCoatings/Electroless.htm This process is better at plating inside details than electroplating.
07/13/2007 7:06 AM
Why plate, instead of using a solid nickel tube? What is the application?
07/13/2007 10:50 AM
If it is a high nickel austenitic stainless steel tube I would higly recommend that you take a look at the Kolsterising tretament process.
www.kolsterising.info
Kolsterising can deliver a surface hardness of 68 HRc without dimensional change to the component and without negitively the corrosion resistance of certain austenitic stainless steels.
07/13/2007 12:03 PM
if it is just a surface finish issue you may be able to slurry finish it 2-5 Ra
07/16/2007 9:44 AM
If the length is long compared to the diameter, and you are electroplating, you may need to place a current source inside the tube. The electric field inside a closed surface is zero if there are no sources inside, and a long tube in electroplate solution acts like a closed surface.
casey jones
Anonymous Poster (1); BillM (1); casey jones (1); Nigh (1); PWSlack (1); TexasCharley (2)
