Previous in Forum: Sea Air Space 2015   Next in Forum: Is this Current Generation of "Engineers" Capable?
Good Answers: 444
Free Access to All NFPA Codes
04/15/2015 8:52 AM
For those of us who are "code junkies", just plain curious, or simply insomniacs, I'd like to pass on this link for absolutely free online access to the entire collection of the NFPA codes, including the NEC! You can't print or download (that privilege will set you back $1,395) but you can look up all those pesky grounding questions to your heart's content:
http://www.nfpa.org/freeaccess
I know this is old news and has been previously alluded to twice on CR4, but only for specific documents, so here's the complete set.
Pathfinder Tags: nec NFPA
User-tagged by 1 user
Re: Free access to all NFPA Codes
04/15/2015 9:06 AM
Surely one can use a screen capture program to print a relevant page.
04/15/2015 10:27 AM
Anonymous Poster #2
04/16/2015 5:36 AM
or a cell phone camera, pencil an paper...or have your sextery copy it
04/19/2015 3:43 PM
You pay for the convenience obviously. Don't ruin it for the rest of us unless you want to answer all the NFPA questions on CR4 yourself rather than posting a website link!
Good Answers: 203
04/15/2015 1:08 PM
For those unfamiliar with the NFPA codes, they take a little getting used to. Even those familiar with codes might initially get confused. Initially the Index is the first important item. Some of the code titles are not very descriptive for the layman. What is a pumper? A vehicle which primary purpose is to pump water and extinguish the fire with water but is it an fire engine? What is the difference between a "ladder truck" and a "platform ladder truck"? What is the difference between "tender" and a "tanker"? What is the differences between an "initial attack pumper" and a "class A pumper."
There is also not much rhyme or reason to the assignment of code numbers. Each code has an effective date and a "review/revision" date. Use the code index first. Then go to the initial page for that code. Look at the index for the code and then go to the applicable page. CAUTION- some parts are identified by the code and its sub codes. i.e. 70.3.4 and some reference the code and the page the applicable part is.
If you need a hard copy or one that can be made into a file (pdf or similar) contact your local fire marshal, fire prevention office, or other fire administration office. They usually spend the $1,395 and either have a paper set of the 13 volumes or have it on CD. They are usually cooperative.
The differences cited above are: a pumpers major purpose is to pump water and extinguish the fire. It also carries tools and hoses. It is also referred to as an engine. A ladder truck has an extendable remotely controlled ladder mounted on the body. A platform truck looks like a cherry picker with the platform at the end of the ladder. These are often referred to as "trucks" and their personal are sometimes called "truckies". Their assignment, among others, is to do searches, venting, etc. They usually use tools and not hoses. A "tender" is a vehicle whose primary purpose is to carry large quantities of water, usually between 1,000 to 4,500 gallons. A "tanker" is the airplane that carries and drops water on the fire. These are all standard terminology set by the NFPA for fire fighting. As you can see the codes can be difficult to locate and understand by the layman. The "N"ational "E"lectric "C"ode, Section 70 is no different. Read it carefully!
Although this only references fire standards, all of them can be difficult. Fire standards are cited because the standard 70, NEC, would make a difficult example to understand.
Anonymous Poster (2); jack of all trades (1); old salt (1); redfred (1)
