Previous in Forum: Installation MV Capacitor   Next in Forum: Internal Arc Containment - IEC 61641: 2014
Tripping 6.6 kV Motors on NPS Protection
04/16/2015 2:49 AM
pl. clarify - there was a system disturbance in the 400 kV system, which has led to tripping of 210 mw generator on Class B protection - Negative Phase Seq Stg-2 and subsequently, the numerical relays of HT motors have acted on NPS protection and tripped HT motors...Why pl. Clarify..?
Good Answers: 445
Re: Tripping 6.6 kV Motors on NPS Protection
04/16/2015 11:47 AM
The relays acted properly. You have to look at what causes a NPS relay to operate; i.e., they detect high levels of Negative Sequence voltages/currents, depending upon the exact type.
You didn't say what the nature of the system disturbance was, but assuming it was a single line to ground fault then the remaining two phases essentially continued to power the system as a severely unbalanced single/three phase system (depending upon the transformations between the fault and the relaying).
This in turn caused negative sequence currents to flow far in excess of the 5% trip level that the machines' protective relays may be set for. Given the fact that it reached as deep as the generator the fault must have persisted for quite a long time, long after the HT motors tripped.
Did something take out a tower or get tangled in the conductors?
