Previous in Forum: Specification of a Log Grabber   Next in Forum: MakerFaire
Hydrostatic Testing Of Buttweld Fittings
07/12/2007 12:45 PM
Dear friends,
I had calculated proof test pressure as per formula given in asme b 16.9 for verrius type of material and sch. (wall thickness) , i found value come in psi. Is very large 20000 lbs to 38000 lbs. As assembly is reqiuried to withstand, without rapture, 105 per cent of the computed proof test pressure as defined below.
Computed proof of test pressure = 2 x actual tensile strength of the test fitting x nominal pipe wall thickness/ by specified outside diameter of pipe.
I had tried to find out source who can undertake this type of high pressure test and certify fittings, but i could not get any body here in india. So i request every body if you know any sours / inspection authority please let me know on this forum or on my email address given below.
Vdd_56@ yahoo.co.in
Thank you
V.D.DEODHAR.
Re: HYDROSTATIC TESTING OF BUTTWELD FITTINGS.
07/12/2007 1:13 PM
please note: your high psi limit is only going to be as great as your lowest rated component. The pressures you are describing are enormous.
Engineering Fields - Piping Design Engineering - Environmental Contractor United States - Member - Born, raised and proud to be Texan Safety - Hazmat - New Member
Re: Hydrostatic Testing Of Buttweld Fittings
07/12/2007 4:27 PM
May I ask what kind of system you are working on?
Believe none of what you hear......and only half of what you see.
08/22/2007 3:11 AM
Dear friends,
I had noted your poins,thank you.
Actually, I wanted carry out this kind of test, in order to et registered our buttweld fitting made as per asme b16.9 duly forged & machined. so I had submitted my dimensional catalog ,list of matl. is used and the calculations of hyd.testing as per ASME B16.9. The concern authority said you calculations are correct but now, you have to prove the same by carry out test and submit the report in order to get approval .(CRN)
We have got there approval for our flanges form 1/2" to 48" - 150# to 2500# as per ASME B16.5 & 16.47.
Thank you.
v.d.deodhar.
07/13/2007 8:59 AM
Piping is normally tested at 1.5 times the maxmum operating pressure / Design pressure unless the operating temp. is high enough to reduce the allowable stress in which case the allowable stress to be considered will also be lower giving higher wall thickness. Also in such a case the test pressure at ambient temp will become higher.
Hence I don't understand why do you need to test the fittings at proof test pressure.
08/06/2007 10:48 AM
Surely fittings don't need to be tested individually? To do so would overlook the joints and other clutter needed to join everything together. Wouldn't it be better to proof-test the entire system as an assembled entity by demonstrating it to the satisfaction of the local insurance company's inspecting engineer?
kasharma (1); Pepper (1); PWSlack (1); TexasCharley (1); vidyadhar deodhar (1)
You might be interested in: Hose Fittings, Tube Fittings, Gas Fittings
