Next in Forum: Germany giving up it's nuclear power by 2020?
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Mill River Dam Deteriorates, Downtown Closed
10/18/2005 9:15 AM
The city of Taunton, Massachusetts (USA) has evacuated residents, canceled classes and closed off the downtown as a dam upstream on the rain-swollen Mill River continues to deteriorate. Officials fear that the collapse of the Whittenton Pond Dam could unleash a wall of water up to six feet high. The dam passed a safety inspection two years ago, but 16+ inches of rain have fallen over the past eight days.
Engineering Failure?
10/18/2005 10:18 AM
If the dam breaks, does this story represent an engineering failure? Is it reasonable to expect such a structure to withstand 16+ inches of rain in an eight-day period? Does this much rainfall represent an extraordinary event that none could anticipate? Comments, please.
Friend of CR4
Re:Engineering Failure?
10/18/2005 11:52 AM
Any time a dam breaks its a failure, although not necessarily an engineering one. I'd consider the following "engineering failures":
* Design flaws
* Using improper benchmarks or risk/benefit analysis
* Using substandard materials
* Neglect of general upkeep or necessary repairs
Of course many of these can be enhanced or caused by "political failures" - most notably economic cutbacks, limitations on the plan for economic reasons, or lack of upkeep due to cost.
To answer the primary question though, I don't think it would have been unreasonable to expect 16 inches of rain over 8 days. But I, of course, know the end result so I'm not sure what I would have said a month ago. I can just as easily say that the New Orleans leeves should have been 50 feet thick and 100 feet tall...
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Good Answers: 74
Re: Mill River Dam Deteriorates, Downtown Closed
04/20/2009 3:11 PM
Moose, your first link doesn't seem to work.
An additional 16" of water is equivalent to a pressure increase of 83 pounds per square foot over the face of the dam. If that is enough to cause the dam to collapse, then the safety factor was not adequate in the first place. That may be deemed to be a design failure.
Can't they release the water at a faster rate to mitigate the problem?
Bruce
Register to Reply 3 comments
ba/ael (1); Chris Leonard (1); Steve Melito (1)
