Previous in Forum: Part Ingersoll Rand (Old Type)   Next in Forum: Torque and Power
Westfalia Purifiers
04/27/2015 10:30 AM
HI Gents , M having oil leak from water side in Westfalia Seprator OSC 15-02-67 .
Previously timer for dispacement water was 1 sec and desludge timer was 30 minutes .
After few minutes of running water seal breaks and oil starts coming out from water side giving high flow alarm .
After changing timer to 4 sec and 1 hour respectively , the oil leak was stopped , however it seems that water was now going in oil side as i got high water content in clean oil.
Seems like there is a problem with interface position in purifier.
Any input on this problem will be helpful . Please post guys.
Good Answers: 122
Re: Westfalia Purifers
04/27/2015 10:44 AM
Either the system pressure is too high or the seals are not the correct material for the application or the equipment is not properly mounted or any/all of the above.
Review the operations manual (IOM) to ensure all installation, operation, and maintenance requirements are being met and if so; contact the manufacturer for proper guidance in addressing the issues.
04/27/2015 4:30 PM
Yep. Telephone the equipment manufacturer. Always a good start.
Register to Reply 2 comments
