Previous in Forum: DG Set Sizing   Next in Forum: ups!!!
test standards required
07/13/2007 1:31 AM
what is the stndard test data for
1) EARTHING TEST
2) High VOLTAGE insulation test.
The above should be for units which are approx 25KW power consumption working on 3ph+ N +Earth.
I need to have the saftey guidlines with required data.
Pls advise ASAP
Regards
Rajesh
Re: test standards required
07/13/2007 7:21 AM
Refer some IS or IEC standards and get all the information you require.
BNDas
07/14/2007 7:17 AM
For Earthing test:
For all electrical installations: less than 5 Ohm ( in rocky areas allowable upto 7 Ohm)
For Lightning conductor:the combined value of the earthing system shall be less than 10 M.Ohm
For High voltage test:( should withstand the RMS ac voltage applied across frame & live parts for 1 minute)
For fractional HP motors of rate voltage <50V - 500V ; above 50V upto 250V - 1000V
For motors 1 HP to 3 HP - 1000V + 2*rated voltage
For motors above 3 HP - 1000V + 2*rated voltage
( subjected to maximum of 2000V)
