It's certainly possible - you need to look at the drive circuit to see if it's compatible with a MOSFET. And choose a MOSFET with substantially higher breakdown voltage and power handling capability than you think you need - that will give you a more reliable design.
The darlinglon will be driven via a resitor or potential divider ...and will need about 1.5 v drive...
The mosfet being voltage driven may well be fine as it won't drop any volts through the feed resistor and will probably turn on at about 3 volt (if the right one is chosen).
In other words ....yes it may well work ..
Funny that's what I said initially...
But yes , you may need to mess with the drive circuit...but I'd have thought you'd know that...and check the voltages...and spec's
Mosfet drive circuit and darlington drive circuits are very different . So even if it works for few minutes , is not a good engg solution . The drive pulses are lot different.
tanks for your interest, and sorry to answer so latelly .
I am not responsable for the project and I was trying to answer to a friend about this.
In any case , the time is for hollidays...wiiiiii:)
we dont see much trouble in replacing the transistors, but there are a lot of if´s since they are microcontroled , so trigger timings must be carefully revised!
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
