In our power station, we are using C&S make,mrr1 rotor earth fault relay, in which the value is fluctuating from 75 K-ohms upto 400 K-ohms. 80 K-ohms is alarm setting and 5 K-ohms is Trip setting.
What may be the probable cause for the fluctuation? I already changed the relay with a new one, but still problem persists. Local brush contact, grounding, cable IR value everything checked and found normal. Any suggestions regarding this problem..?
