Previous in Forum: Earthing Clasifications and Advantages   Next in Forum: How to repair crack rotor bar for induction motor
HT motor
07/13/2007 10:22 PM
Why HT motors are star-connected?
Re: HT motor
07/13/2007 11:43 PM
It is highly unlikely that a HT motor would ever be started by the star/delta method. By star connecting the Volts/Turn is reduced to the minimum.
Greg Lynch
Re: HT motor
07/14/2007 2:55 AM
Hi,
I`ve got 24 Nos.HT motor which all are star connected reasonbeing insulation level as we aware in star mode phase voltage become V (line)/1.732 mean we have saved insulation for that system.Suppose we choose delta connected HT motor we will have to increase insulation level.It will bw sheer wastage of money beside it size of motor become too large.
Good luck
tadagids
Re: HT motor
07/14/2007 4:30 AM
Thanks for reply,
What about torque? Delta connected motors have more torque.
Re: HT motor
07/14/2007 4:48 AM
Raja,
Good question.
We know about torque but economy also prime factor for an engineer .If you ask for torque then go for Slip Ring Motor so that one can insert resistance in its rotor circuit & can increase torque accordingly .Check torque formula for induction motor.
Good luck
tadagids
Good Answers: 12
Re: HT motor
07/15/2007 11:19 PM
Good reply on the both cases.
Subramanyam
Re: HT motor
07/16/2007 4:39 AM
It is the mechanical load that presents the torque/speed characterisitics to the motor, and motors and their starting arrangements must be selected with this as a primary consideration.
Re: HT motor
07/20/2007 3:28 AM
In HT motor by connecting in Star u have only one weak spot. Connecting in Delta would mean three joints. Though voltage will be rated by 1.732 full insulation is used and not graded insulation as done in case of transformer because the HT voltage levels used max are 11KV (Though some 33KV motors Have been reported to be in use.)so saving in insulation will not result in cost reduction.Torque has nothing to do with connection.Torque is KW*K /speed or RPM.Type of connection won't make any difference.The reason they are always in Star is no advantage is gained by using delta,On the other hand weak spots are more.Secondly a neutral point helps in Protection.
Register to Reply 7 comments
Anonymous Poster (1); kvsubramanyam (1); nesubra (1); PWSlack (1); raja123 (1); tadagids (2)
You might be interested in: DC Motors, Stepper Motors, AC Motors
