Previous in Forum: Koche/Koken   Next in Forum: Testing a Viscous Coupling
8 comments
Gimlet Point Machine Screw?
05/20/2015 7:16 PM
Greetings.
A quick nomenclature-related question: What is the proper name for a machine screw with a constant-pitch tapering tip? It's essentially the machine-threaded version of the common type AB self-tapping product.
I've seen grade 5 specimens of this type from time-to-time in older vehicle assemblies; and have referred to them as "gimlet point machine screws."
If anyone has some quick savvy to share, is there a correct name for this item?
Thanks!
Re: Gimlet Point Machine Screw?
05/20/2015 9:01 PM
Hex head self-tapping screw?
Thread cutting machine screw?
05/21/2015 12:02 AM
I don't know if your term is standard, but it makes perfect sense and is understandable. I think I've heard of it before, but am not sure.
05/21/2015 12:53 AM
The screw you reference is designed to penetrate sheet metal.
No thread cutting provision is needed. They join two very thin profiles together. Their wide pitch accommodates two thin sheet metal plates.
"Self tapping machine screws" are designed to tap, thread and fasten metal with profiles thicker than "sheet" metal.
05/21/2015 9:16 AM
Thanks for the input, folks.
Here's a pic I dug out of the Grade 2 variety:
As you can see, it's not a typical sheet metal screw; nor is it a self-tapping machine screw (at least in the conventional sense). It's a conceptual hybrid of a true machine screw and a type AB sheet-metal product (the first of SolarEagle's posted images).
Can indeed still call it a "gimlet point machine screw" in casual prattle, but it'd be a welcome relief to finally get the thing out of my craw (too many years in the back of the head)!
Itch, itch, itch...
Thanks again --
05/21/2015 1:48 PM
Selfie!
Type CA.
Ahhhh... Great scratch
Cheers!
05/21/2015 2:39 PM
type CA point
"Type CA point: A thread forming screw with either coarse or fine pitch machine screw thread. Same as Type C except with a Gimlet point. Thelocating point works better than Type C where holes between two adjoining pieces of sheet metal may be somewhat misaligned."
http://elginfasteners.com/resources/screw-point-types/
http://www.taptite.net/pdfs/documents/TAPTITEII-CONTI-reminc.pdf
Good Answers: 25
05/21/2015 11:09 PM
"Gimlet point machine screw/bolt" is the engineer's nomenclature; the guys who regularly bust their knuckles call them "fender bolts" because they are used to hold auto body panels together. Much quicker to use on an assembly line for things which might not be lined up well enough to start a "regular" bolt without risking cross-threading.
Canada - Member - New Member
05/22/2015 9:52 AM
Might want to look up SEMS type screws. Check them out on spaenaur sight for the many different styles.
Never stop learning
Register to Reply 8 comments
Ed Watts (1); Insatiably_Curious (2); Kevin LaPaire (1); lyn (1); SolarEagle (2); Tornado (1)
