Previous in Forum: Hydraulic Testing of Pumps   Next in Forum: Direct Injection Diesel Engine
Egypt - Member - New Member
Electric Motors and Diesel Engines
07/16/2007 1:43 AM
please i wanna know the diffrence between the electrical motors and the diesel engines in the performance and its effect on the driven objects
South Africa - Member - ShoSholoza Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member
Re: electrical motors and diesel engines
07/16/2007 3:24 AM
I think you need to think of the infrastructure that will be required for each type of drive & the purpose that each drive is expected to fulfill.
Diesel engines would generally be used in isolated areas when electrical infrastructure does not exist or will be difficult or costly to implement. Diesel engines also used for emergency [eg firepumps] applications when elctrical supply maybe interrupted.
Electrical motors generally cheaper and more reliable than diesel engines. In addition, for instantaneous starting, electrical motors may have the edge on diesel engines.
For classified [hazardous] areas, electrical motors maybe the easier & cheaper option.
What is the driven equipment and service?
Can you imitate yourself?
07/16/2007 3:49 AM
thank's Hammer for answering me, the driven objects are pumps
and i wanna know will the hydrolic test readings be more acurrate in the case of motor than the diesel
07/16/2007 4:58 AM
Eh?
Hydraulic test measurements will normally be carried out with the pump not running, so as to confirm the ability of the wetted part of the equipment to sustain a given test pressure.
Dynamic test measurements will be carried out with the pump running so as to confirm, or even plot in the first case, the pump erformance curve.
Neither test is in any way related to the type of motive power used to turn the pump.
Register to Reply 3 comments
heba abd el moneam (1); PWSlack (1); The Hammer (1)
You might be interested in: DC Motors, Stepper Motors, AC Motors
