PRTV outside power equipment insulates with
takes shape permanence anti flashover compound coating
PRTV outside power equipment insulates with takes shape permanence
anti flashover compound coating, is a kind of
electrical power system uses the new electrical function material, it's
specially for the electrical network and each round, loses, uses electricity
the customer to be lasting eliminates the equipment flashover thoroughly the
hidden danger then to design, It's developed jointly by the North China electric
power academy of science with our company successfully. The product has the
unique chemical composition and the structure, achieved and surpasses the heat
vulcanization silicon rubber physics electrical specification, Overall
performance and so on more outstanding water repellency nature, as well as 20
years design service life has provided a kind of new technical measure for the
electric porcelaneous equipment permanence counter- dirt.
1.
Product Execution
Qualification
This uses the North China electric power group company standard
"Outside the Power equipment To insulate with Takes shape the Permanence
Anti flashover the Compound Coating (PRTV) To use Leads Then", With Hebei
silicon valley chemical industry limited company standard Q/HGH 019-2004
"Outside PRTV Power equipment Insulates with Takes shape Permanence Anti
flashover Compound Coating" to organize the product the production and the
construction.
2.
Range of application
This product mainly uses in the electrical power system transformer
substation and the transmission line insulator, the power plant and the
electric power user changes outside the electricity equipment as well as other
electrical equipments insulates lastingly anti flashover . After the porcelain
(or glass) the insulator uses this product, Forms the porcelain (or glass) the
skeleton complex effect, Enhances one kind of standardized disposition plan
which outside the power transformer equipment insulates. Is suitable in
alternating and direct circuit system rated voltage 1~750kV, Environment
Temperature -50℃~ +50℃, Under the contamination condition
moves outside the transformer substation and the impractical transmission line
equipment insulates antifouling, Prevention flashover, Enhances the equipment
outside to insulate the rank.
3.
Operation Guide
To porcelain (or glass) insulator superficial thorough clear dirt,
Removes the contamination, the fat and other attachments, After waits the
electric porcelaneous surface pure to be dry, May use to spurt spreads or
brushes spreads and so on to spread spreads the method to carry on the
construction, Coating thickness is 0.5 ~ 0.6mm,
the coating should leak proof spread, not dribble, does not hang the silk, The
surface is smooth, levels also does not have the air bubble. Originally has
used the RTV equipment, Should be clean the unreliable attachment cleaning up,
remove the contamination, After uses the special-purpose processing medicinal
preparation to clean, Again executes spreads PRTV.
4.
Package and Storage
This product packing in airtight metal container, When storing and
transportation should maintain dry and ventilates, Prevented all day exposes to
the sun, the rain drenches. The storage time is 1 year, Duplicate surpassed the
storage time after to examine qualified still may use when the coating uncaps
the use, if has not used up, Should cover securely immediately the airtight
preservation.
svchem65@yahoo.com.cn
