Previous in Forum: Pull Or Push: Pumping Water up to 15ft in Height   Next in Forum: SS Welding to Steel
12 comments
Aluminium Deformed Bar
06/16/2015 11:31 PM
Steel deformed bar is very commom, but anyone has seen aluminium deformed bar?
Re: Aluminium deformed bar
06/16/2015 11:45 PM
No.
06/16/2015 11:52 PM
06/17/2015 3:15 AM
Any coupler for rebar?
01/20/2016 8:31 PM
do you need rebar coupler? if you want ,we could supply, high quality and price competitive. lola***
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
lola_zhang@ocepo.com
Good Answers: 92
Re: Aluminium Deformed Bar
06/17/2015 2:02 PM
Yes. I've dropped a heavy object onto aluminum bar, and boy, did it deform it.
All joking aside, why? If you are referring to rebar aluminum would be a lousy choice in concrete- a friend of mine just did a job that required stainless steel rebar.
06/17/2015 2:47 PM
Yes. I tripped over a load and bent them only last week.
Good moaning!
Hobbies - CNC - New Member
06/19/2015 3:02 PM
Youngken,
What are you looking for?
A lightweight rebar or just Aluminum rebar profile.
What's your mission soldier?
06/20/2015 7:48 AM
A light weight rebar which can be used with coupler (can be threaded), most probably aluminium rebar
06/20/2015 10:22 AM
I think there would be issues with corrosion between the aluminum and concrete. Are you looking for a lightweight reinforcing solution? Look at the Basslt rebar or look at some type of tubing. How much do you need?
Good Answers: 179
06/20/2015 10:46 PM
I don't see the logic of wanting a lightweight (as in Aluminum) reinforcing bar in a concrete structural element when the bar weight is such a tiny percentage of the total weight.
Also, aluminum reacts terribly with alkaline concrete.
Additionally, aluminum doesn't not exhibit the same ductility as steel rebar, hence you will most likely encounter a catastrophic failure (with no advanced warning like you would with steel reinforcement) of a concrete structural element.
06/20/2015 10:55 PM
Agreed!!!
Good Answers: 19
06/27/2015 1:25 AM
One advantage is installation in difficult to access geographic areas.
One big disadvantage compared to steel is the lack of bending capacity. So straight bars only ?
omw7
Register to Reply 12 comments
CaptMoosie (1); Crabtree (1); JNB (1); lola (1); lyn (1); omw7 (1); Original_Macgyver (3); SolarEagle (1); youngken (2)
