Previous in Forum: Chemical Composition Question   Next in Forum: Recycling Bottle Caps?
Perfect Crude - Water Separation
07/16/2007 10:26 AM
how can we get perfect crude - water seperation?
Re: seperation
07/16/2007 11:12 AM
Crude. Let's see. Crude oil?
Re: Perfect Crude - Water Separation
07/16/2007 11:01 PM
"how can we get perfect crude - water seperation?"
Centrifuge.
Steam Distillation.
Gravity in large tank.
07/17/2007 12:06 PM
If you are talking about separation of crude oil and bottom sediment plus water (BS&W) for crude oil storage tanks in an oil refinery, there is no economically practical way to achieve a perfect separation.
If you are talking about separating and removing oil from the wastewater entering the a refinery wastewater treatment unit, then most refineries use either of the following:
(1) An API gravimetric separator followed by dissolved air flotation DAF.
(2) A parallel plate interceptor followed by dissolved air flotation DAF.
Either of those usually usually results in reducing the oil content of the wastewater down to 5 to 10 ppm which is not a perfect separation but good enough to enter the next step in your wastewater treatment unit.
If you are talking about separating crude oil and water on a laboratory scale, then one of the other responses has suggested centrifuging or or distillation ... although I'm not sure they would provide a perfect separation.
Milton Beychok
Anonymous Poster (1); mbeychok (1); Stirling Stan (1)
