Previous in Forum: California Drought   Next in Forum: What Is It, Where Do You Find It?
14 comments
Alarm System?
06/21/2015 4:26 PM
We have installed a DSC 1832 security system in a laydown yard. There are two office buildings and several shipping containers that we installed motion sensors inside for security. There are no other sensors involved.
We have a PC1864 set up with SENS-1200 (PIR)sensors.
Zone 1 has 3 SENS- 1200 detectors
Zone 2 has 6
Zone 3 has 2
Zone 4 was recently added with 10 SENS-1200 detectors originally. When the system was armed the zone would trip after about 3 minutes quite consistantly.
We set the sensitivity to low on all sensors on zone 4 and reduced the total number to 5. We are still getting alarms but now after 45 to 90 minutes later.
The sensors we added on Zone 4 are slightly different (newer model) than the first ones we had installed but we are using them in conjunction with the older ones installed in zones 2 and 3. Even with high sensitivity selected they have no problems.
All the sensors are installed inside shipping containers of similar size and installed in the same location in each. Voltage on the power terminals remains at 13.6 VDC, current draw of the individual sensors is about 8mA.
TYCO is the parent company but has never responded to any of my inquiries. I tried contacting the vendor we bought from but they have not been helpful either.
I would like to know what other things may cause these PIR sensors to trip intermittently and why the time delay. Thanks.
deanpavil
Re: alarm system ?
06/21/2015 6:25 PM
Why did you not "have" it installed and started by professionals?
There's no diagnostics program?
Operator's manual?
No troubleshooting guide?
No qualified on-staff personnell?
No vendor support indicates a cut-rate supplier that does not care about customer service.
Remember, you get only what you pay for.
Can you give some indication that you may have tried some remedies yourselves.
PC1616/PC1832/PC1864 User Manual - DSC
Security System Control Panel - PC1832 | DSC ...
How to use your DSC Security System - Full Video - YouTube
Re: alarm system ?
06/22/2015 2:52 AM
Thanks for the comments.
This site is in a remote section of Africa. The cost to get a "professional" installer to site was cost prohibitive.
We had installed a similar system earlier and it has been working fine.
Diagnostics on the system show all zones are good.
We are qualified but evidently this is a bit above our pay grade.
The vendor is happy to send a tech to site but that brings us back to the first point mentioned.
Lyn, thank you. but I have and have seen all the links you mentioned.
The 2 offices we have secured have windows and those zones do not have any issues. The diagnostics show the "fault" actually, alarm; comes from the latest Zone that was added which consists of the PIR sensors installed in steel (overseas type) shipping containers. One of the previously installed Zones has 6 PIR in series. This zone has been working fine. When adding the additional Zone with 10 we started having problems. This new Zone we can keep it working but with only 5 PIR sensors.
Other than a yard security light there is no electrical interference. No radios, no cars, no lights, not a single luxury.
We have monitored the power supply , measured the resistances on the cables to the different zones.
In the evening when the system is activated the sun is on the back side of all the containers. The sensors are all mounted at the front (door end) facing East. Containers are all empty so no mice or rats. Maybe some spiders but they can't be that good that they know when we activate the alarm and set it off 5 minutes later.
I was disappointed that I was not able to get any support from the parent company. All I was looking for was some data on how many PIRs and what the maximum distance would be for a Zone installation, as that is my hunch of what is causing the issue.
deanpavil
Good Answers: 141
Re: alarm system ?
06/22/2015 7:19 AM
I think connecting PIR sensors in series brings down accuracy. Can't you get more separate inputs? Or an alarm system with digital addresses?
Your Pir sensors point to a steel wall where the sun is at? How is the temperature of the wall inside changing? What color is the wall inside and outside?
Have you been inside when locked?
No light beams or straw lights?
Plenty of room here
Re: alarm system ?
06/22/2015 9:04 AM
That was what i was trying to determine was the operational effects of running that many in series.
We ran out of cabling to make anymore individual zones.
There are no light beams or straws.
the inside walls are flat red oxide (looks like red primer coat) or flat grey. Outside is flat red or ivory (cream . Morning sun gets hot but also on the containers that are working. I haven't gotten any actual temps.
I'm heading out to the site tomorrow to look it over again to see what we can do as they want to use the remaining containers now
deanpavil
Good Answers: 141
Re: alarm system ?
06/21/2015 7:28 PM
Are there windows involved? Sun, steel container bodies?
Pir sensors also could signal variations in temperature (steel surfaces) or light variations (windows)
Plenty of room here
Re: alarm system ?
06/21/2015 7:44 PM
A little troubleshooting is called for...
http://www.zen22142.zen.co.uk/ronj/fls.html
Re: Alarm System?
06/22/2015 8:58 AM
Who manufactures the SENS-1200 units (or, better, can you supply a link to a datasheet)? A Google search was unproductive. What is the resistance of the loop of 10 PIRs in series?
Re: Alarm System?
06/23/2015 9:40 AM
Alarm sensors frequently have a resistor in series with the alarm contacts, and sometimes another in parallel, so that tampering (short circuiting, or cutting the cable) can be detected. It's possible that this PIR has such resistors, and that the total resistance of several in series is too close to the tamper detection limit of the control unit (which is kinda what SHOCKHISCAN was saying in #11, and what I was trying to establish above).
Re: Alarm System?
06/22/2015 11:03 AM
Hasn't been mentioned yet, but another thing to check might be the end-of-line resistor to make sure it is of the right resistance. Since you installed the other zones with no problem I'm sure you have checked that when you added this zone.
When Somebody Tells You Nothing Is Impossible, Ask him To Dribble a Football.
Re: Alarm System?
06/22/2015 1:34 PM
Check that no building and no container contains unwanted higher biological entities:
  • Mice
  • Rats
  • Dogs
  • Feral cats
  • Birds
  • Illegal immigrants
  • Etc., etc.
Good Answers: 125
Re: Alarm System?
06/22/2015 3:21 PM
Your zones respond to current draw, not a closed contact (although that is the ultimate current draw).
Check your current draw on this zone.
Another couple of possibilities:
1. One of your sensors is bad
2. You have something in the area of this fourth zone which emits some type of RF radiation.
3. You have a wiring issue.
Good Answers: 122
Re: Alarm System?
06/23/2015 9:25 AM
The End-Of-Line resistance/impedance device is most likely not correct.
It is imperative that you install the correct size resistor and/or other device at the end of the sensor circuit.
The needed information for sizing the EOL should be available in the OEM installation manual.
If not, then measure each circuit current flow in the circuits that are operating correctly then calculate the size of resistor needed in the problem circuit that will raise or lower the current flow to match the operating trouble-free circuits.
Re: Alarm System?
06/24/2015 5:02 PM
THere is no EOL resistor in these circuits. A tamper switch and the output switch are all in series with all the PIR sensors.
WE placed the last 10 sensors on 2 zones with 5 sensors each. So there are now 5 separate zones. Zone 5 is still having problems as it alarms after about 40 minutes with nothing apparent in the zone.
The resistance on each circuit (zone) varies. Zone 3 is close to the panel with only 2 sensors with a resistance of 53 ohms. Zones 4 and 5 each have 5 sensors and farther away, measure 210 and 235 ohms.
Each of the 5 zones are drawing 0.7mA on the switching circuit. We are using 22 AWG and the OEM manual says that is good for 3000 ft. Our longest run is about 1400ft.
THe power supply for the panel is rated 12VDC at 500mA. Total load with all zones was 180mA. and 13.6 VDC at the panel.
We noticed that the power voltage at the last sensor on zone 4 (which is working correctly) was 9V. The voltage on the last sensor on zone 5 was 8.7. The voltage on the first sensor on zone 5 was 9.5V. When the other 4 sensors were removed from the circuit the voltage went to 12V. The single sensor was drawing 13mA but when the other sensors were added back in the current stayed the same but the voltage dropped.
Not sure what gives there.
The silk screen on the circuit card of the sensors showed the name SensorPro SENS1200-Q. Not been able to find anything on this critter.
Going to look at this again tomorrow to see if there is a bad sensor we can isolate.
any other ideas?
deanpavil
Good Answers: 125
Re: Alarm System?
06/26/2015 4:04 PM
You likely have a bad sensor on (now) Zone 5.
Also, if your readings tell you that 5 sensors are drawing the same current as 1 sensor, your meter is bad as well.
I would wirenut the "in" and "out" wires at each sensor together, one at a time to determine if you have a bad apple.
Register to Reply 14 comments
deanpavil (3); dvmdsc (2); JohnDG (2); lyn (1); PWSlack (1); SHOCKHISCAN (1); Softtail Rider (1); SolarEagle (1); WJMFIRE (2)
