Previous in Forum: Single Effective Speed?   Next in Forum: Need Analysis Help Loads
11 comments
Bleed Valve
07/02/2015 9:19 PM
Hi friends, Good day. We having 4 Alstom 13E1 open cycle gas turbine. this machine was working very good and suddenly tried with 120MW the problem now the unite start up normally and firing but when the HP bleed valve close at 2850rpm the unite trip and only giving fleam off signal.. help us plz. thanks
Re: bleed valve
07/02/2015 9:29 PM
Contact vikneswaran.
He knows everything about these beauties.
Or her, she is the president of the company. She's not bad either.
This is her address and phone number:
  1. Address: 200 Great Pond Dr, Windsor, CT 06095Phone:(860) 688-1911
Re: bleed valve
07/02/2015 10:10 PM
That you vikneswaran?
Sounds like you broke it. Fleam off alarm, no idea (flame off perhaps?).
You had better contact Alstom or their service agent. Don't try and operate the unit or bypass the safety alarms otherwise............BOOM (potentially).
Good Answers: 109
Re: bleed valve
07/03/2015 2:35 AM
Should not have tried the 120MW. Apparently it did not like that sudden change.
Is th turbine even made for this?
Close the valve earlier or later maybe - oh hold on - no don't use it at all.
Call the manufacturer support.
Dont get killed.
Re: Bleed Valve
07/03/2015 7:47 AM
we already changed the air intake filters because we thought there is no enough air uncaring to unite Comprasser but the same thing happened again when HP bleed valve close first flame off and circut breaker open and trip
Re: Bleed Valve
07/03/2015 10:40 AM
Why don't you quit wasting your time trying to get it fixed for free and call the tech service people at Alstrom!! (860) 688-1911.
You DO have a telephone, don't you?
Good Answers: 445
Re: Bleed Valve
07/03/2015 3:20 PM
The HP bleed valve is there to reduce the compressor load during startup, and closing it affects the air/fuel ratio. You're getting a flameout because the extra load (and air) from the compressor is not being compensated for with additional fuel, too much air/not enough fuel and the flame cools/gets blown out. You need somebody on-site that understands the fuel management system and how to tune it, this is not a job for amateurs, as others have said...Call the factory...now. The job you save may be your own.
Re: Bleed Valve
07/03/2015 7:40 PM
maby it need to increas the miun strok to add more fuel
Re: Bleed Valve
07/05/2015 3:22 PM
Maby it will just disassemble itself explosively.
You need to talk to Alstom or their agent and get professional help. A faulty 120MW gas turbine is not something we are comfortable at guessing at and neither should you be.
Good Answers: 25
Re: Bleed Valve
07/04/2015 3:01 PM
42.
Re: Bleed Valve
07/04/2015 6:22 PM
whats mean 42 plz
Re: Bleed Valve
07/05/2015 6:44 AM
42 is "the answer to life, the universe and everything". To understand this joke, you need to have a passing acquaintence with " The Hitchhiker's Guide to the Galaxy", which is available at all good booksellers, and possibly on-line for book reader tablet computers.
Good moaning!
Crabtree (1); Ed Watts (1); IdeaSmith (1); jack of all trades (2); khalid gardawi (3); lyn (2); RAMConsult (1)
