Previous in Forum: Bleed Valve   Next in Forum: Long Seam in RF PAD of Pressure Vessel
8 comments
Need Analysis Help Loads
07/04/2015 12:47 PM
I am designing a mounting block for a motor as shown in the figure. I am not sure how to apply loads in Ansys or any FEA package to do a structural analysis . Could anyone please advise onhow to analyze this structure. .
Pathfinder Tags: structural analysis
Re: Need Analysis help loads
07/04/2015 1:26 PM
I question your use of the word "designing" in this context.
Google "Ansys tutorials" find an applicable tutorial and read and learn.
What does, "rotates and travels up" really mean?
Good Answers: 97
07/04/2015 1:29 PM
I thought the question was about some sort of carpal-tunnel support. Never mind!
CRTL-Z
Re: Need Analysis Help Loads
07/04/2015 1:46 PM
6 mm (1/4"0 steel for everything and you will be good to go.
07/05/2015 12:15 AM
The Newton is a measure of force, not mass! Don't confuse mass with force or weight!
Good Answers: 102
07/05/2015 5:29 AM
The OP has kindly used SI force units. Not a mixture of masses and forces or kgf...
Good Answers: 102
07/05/2015 5:35 AM
Can you do a pencil and paper analysis?
There's enough info there to calculate the moments and shear forces that the mount or support will be subjected too.
How much clearance do you require behind the machine, that dimension is missing. The height is also missing.
What is the assembly's purpose?
07/05/2015 5:33 PM
Thanks Wal. The structure I show in black is actually a frame structure to hold the motor. It is about 300 mm wide(clearance about 60 to 70 mm) and 600 mm tall. It is a pick and place mechanism i am working on for bricks transfer.
Good Answers: 102
07/06/2015 1:57 AM
The mount to withstand these forces is not that hard to design and build just with "empirical" material selection.
The wall to which it is secured is the weak link here.
What is the wall material?
Register to Reply 8 comments
dkwarner (1); learnazhu (1); lyn (1); tcmtech (1); Unredundant (1); Wal (3)
