Previous in Forum: Useful Online Calculator Website   Next in Forum: Shell Type Transformer Not Performing as Expected on Low Power Input
16 comments
Parallel Cummins Generator
07/05/2015 7:11 AM
I have 4 Gen. Cummins with PCC-3100 , need to connect them in paralleling .
when i start first one by signal from ATS , how can start 2nd one,3rd and 4th reference to load
and about synchronizing between gen's. depend only on communication between
generators ?
Hope help me
Pathfinder Tags: Generator
Re: Parallel Cummins Generator
07/05/2015 7:53 AM
Tell me what the generator manufacturer said during your last few phone calls.
Good moaning!
07/05/2015 10:31 AM
I contact with manufacture by email and he ask me to contact with distributer im my country but .
07/05/2015 12:01 PM
Again, how did your last couple of TELEPHONE CALLS go, Mildred?
Good moaning!
Good Answers: 225
07/05/2015 9:16 AM
I expect that you would require an automatic load demand control module, likely called something else by Cummins, but most manufacturers offer them for load demand based auto starting of parallel gensets.
They generally have all of the communication and sync processes on board and should be a simple add on to your existing control modules.
07/05/2015 12:49 PM
PCC-3100 is generator controller and its include parallel feature but this point not clear i mean exactly how multi genrators will run if master one run from ATS ,what about another generators how run refernce to load .
Good Answers: 225
07/05/2015 5:22 PM
Whilst it can handle paralleled gensets, I don't think that the PCC-3100 control has the capability to run load demand controls for them.
As I stated earlier, you will likely require an add on module for that bit.
Cummins calls their module a "Masterless Load Demand (MLD) upgrade kit"
It wasn't hard to find...Go to this Cummins site for info...Page 15 tells you about it.
Then do as others have suggested and contact the supplier.
07/05/2015 12:54 PM
The forum cannot do your work for you.
This should have all been done at the time of purchase of the generators.
Call this number: 1-812-377-3000 and tell them you NEED HELP.
Quit wasting time and get on the phone or go here:
Customer Assistance | Cummins
07/05/2015 1:24 PM
The word for today is "synchroscope"; but if your budget is too cheap, you can do it with three lights and as many switches as generators.
Good Answers: 102
07/06/2015 12:38 AM
1 lamp is all you need as long as it can withstand full phase to phase voltage otherwise 2 lower voltage lamps in series does it. Could use a Voltmeter too.
Provided the DGs are rotating the same way then if one phase is synced then so are the others.
07/06/2015 12:59 AM
The three lamps can also cover the case in which one or more gensets are accidentally connected in wrong rotation. You or I might not do that, but the OP is questionable.
07/06/2015 2:15 AM
the lamps is not my problem , where the controller can synchronis its output reference to bus(load) voltage and frequency .
the matter how start the genset regard to load , im looking to run follow one based one load demands , and ask my controller has the feature or not if not i will use current transducer connect to plc.
regards
Good Answers: 102
07/06/2015 6:50 AM
click the link provided by Spades in reply #8
07/06/2015 1:30 PM
Do you know how to use a telephone?
Good moaning!
07/07/2015 5:53 AM
waiting you to inform me how
Good Answers: 102
07/07/2015 7:45 AM
According to the brochure ( have you read post #8 yet?) on page 3 the PCC3300 will do that which you ask in combination with the PowerCommand 3.3 MLD on page 15.
A nice HMI would make it slick.
To upgrade the 3100 ( to work as you desire) you need to read pages 6 through to 14. It's all spelt out for you.
A glance at your 3100's manual would be a prudent move. Go crazy and read the generator and sync panel manuals while your at it.
07/10/2015 10:29 AM
I will use current transducer to get analogue signals and regargard signal i will start and stop genset useing PLC .
Analogue sinals will indicate the load amount
Register to Reply 16 comments
Crabtree (3); lyn (1); MBROTHER (5); spades (2); Tornado (2); Wal (3)
