Previous in Forum: Driving Headphones from a Speaker Output   Next in Forum: BDV Oil Transformer
11 comments
Taps on Primary or Secondary?
07/09/2015 8:17 PM
if i want to make an transformer 240volt in and 110volt out and i want put about 10 taps because of voltage drop in my area. Lowest volt record 180 volt input. Should i put the taps on the primary side of the winding or the secondary side? a variac is expensive in my country. If i make one it would cost me cheeper. i intend to make a 12000 watt transformer but puzzle on one single question "were to put the taps". Primary or secondary, and why should i put it there? I want wind it like an auto transformer so i need this information first before i begin. just want some knowledge so thanks. Thats my main question.
Re: taps on primary or secondary!
07/09/2015 8:54 PM
we've seen this movie
07/09/2015 9:28 PM
Is this the one about the guy who asked the same question over and over.
Kinda like a cheep "Groundhog Day" of CR4?
Reply Score 1 for Off Topic
07/09/2015 9:55 PM
Now, that OT is a cheep shot.
Good Answers: 70
07/09/2015 10:44 PM
Sound like you should start a new thread and complain to the cr4 administration, " somebody is giving out free OT's!!
Hobbies - CNC - New Member
07/10/2015 9:08 AM
Or it's this guy........Fundacion
Re: Pressurizing Non Refillable Cylinders - Rigid Foam
07/09/2015 9:30 PM
Just the one?
I CANNOT recommend you attempt this due to the safety concerns, and designing and building a transformer of this size should NOT be undertaken unless you have proper electrical training and experience.
The fact that you don't know which side to put the additional turns on (and no I am not going in good conscience to tell you) indicates you shouldn't be attempting this yourself. I am assuming you mean turns to increase the output voltage not taps to add input or output voltage selection.
A 12kW variac is going to be expensive anywhere.
Consider purchasing cheap UPS (uninterruptible power supplies) for appliances that don't like the voltage drop.
Good Answers: 42
07/09/2015 9:43 PM
How can you make a transformer with out knowing where to put the tap changer weather in primary or secondry winding. 12000 watts means 12 kilowat quite a big transformer for an amature to make. Get the help of a trained and experienced and qualified Engineer and experienced winder to make it. It is not an ameture's job to make a transformer .
Good Answers: 225
07/09/2015 9:44 PM
If you were building a two winding transformer, then the primary is the best location for the taps. Main reason is that the primary winding is normally on the outside and it is much easier to run the taps from there rather than from the inside.
With an auto transformer, there will be only one winding, so you would design it with taps either side of the 110v point to allow for input voltage variables. you could design it with extra taps out past the 240v point, but this would be a waste of resources.
Be aware that the auto transformer does not provide electrical isolation as does a two winding transformer, it also has lower input surge protection and, in the event of a winding insulation failure, can deliver full mains voltage to the load.
You must be careful to get the active and neutral connections right as any discrepancy can cause a safety hazard with the rest of the installation.
07/09/2015 9:50 PM
he can put taps on the side, inside outside etc. until he corrects his line voltage its a waste, transformers are not a substitute for poor supply voltage.
07/09/2015 10:37 PM
Given the auto transformer configuration I would suggest putting the taps on the primary end.
Good Answers: 42
Re: Taps on Primary or Secondary?
07/10/2015 6:07 PM
A servo voltage stabiliser is the solution for your problem. That will provide constant output voltage what ever is your input voltage. That is what is used in locations where there is constant voltage fluctuation . A 10 step tap changer ( even if it is auto controlled ) will not give constant output voltage as the correction is in steps. Servo motor voltage stabilisers are available both in single phase and three phase. The cost is also reasonable. If you are still bent upon making a transformer then make an auto transformer and auto controller and a servomotor which you can locally purchase and assemble the unit.
dj95401 (1); Fredski (2); jack of all trades (1); lyn (2); Original_Macgyver (1); spades (1); tcmtech (1); V.I.Abraham (2)
