Previous in Forum: Pressure Release Valve Spec?   Next in Forum: Centrifugal Pump - Unique Venting Arrangement
API Tank- Stress relieve
07/11/2015 7:53 AM
Dear Expert,
As per 650,para 7.2.3.6, Completed weld of stress relieved assemblies shall be examined by visual,as well as by magnetic particle or penetrant methods,after stress relief,before hydro test.
Question:
Is it required for shell to shell weld(butt joint) MT or PT.
Love to learn
Re: API Tank- Stress relieve
07/11/2015 11:02 AM
Yes, if the complete para is invoked. 7.2.3 Shells
Relief may be found here: 7.2.4.1
07/12/2015 12:08 AM
If the code calls for mandatory testing, then it must be done, or the unit does not comply.
Register to Reply 2 comments
