Previous in Forum: Removing Thinset From Concrete - Any Brilliant Ideas?   Next in Forum: Absorption Chiller
How Eliminate Weld slag after plasma cut
07/18/2007 2:30 PM
I need eliminate Plasma slag after the cut in carbon steel and stainless steel plates the high temperatures produce a thin cover in the cross-sectional area, the thickness measures are 1", 1-1/2", 2" right now in the plant we have a revolving machine, but the quality is not the best.
JHOC
Canada - Member - New Member
Location: Richmond Hill, Ontario (North Greater Toronto Area), Canada
Re: How Eliminate Weld slag after plasma cut
07/19/2007 2:50 AM
I am only aware of the common method, which is grinding. Or use a cutting method with less slag, such as laser or water jet. It could be worse, you could be flame cutting!
You can have it good, fast or cheap. Pick two.
07/19/2007 6:16 AM
Chemetall Oakite (www.oakite.com) has several laser scale and plasma scale removal chemistries that prepare the part for painting etc. Call your local rep for Oakite and get some info from him/her.
Ed Ruscher e.ruscher@insightbb.com
07/19/2007 8:35 AM
I would call in an ESAB plasma expert. This is likely related to your choice of plasma gases, water in the system if you are using an air plasma system or a choice of consumables and operating parameters.
Cutting speed can also play a role. depending on the material thickness, you may require a different system.
I know ESAB as I worked for them for many years and I am convinced they know more than any of the other system manufactures based on my experience with them.
07/19/2007 4:39 PM
Sandblasting or vibrate finish.
Pineapple
Register to Reply 4 comments
