Previous in Forum: Issue of Silica Gel Turning Black   Next in Forum: Estimation Of Static Tensile Force Of Flexible Conductor
Looking for a 'Dumb' USB Battery
08/03/2015 11:34 AM
Hi All,
Being driven to distraction looking for a USB battery pack that isn't trying to be smart. Or if it is, I can tell it not to be.
I'm looking for a charger that does NOT turn itself off. I need it to support a GPS device in my rucksack over several days. The internal GPS battery will not last long enough. The GPS & USB battery will be sealed in waterproofing and I will have no access to it. So I don't want a USB battery that will charge my GPS tracker once, then shut off. I want it to maintain the voltage until its battery is empty. The GPS is fine with this behaviour. Quite likes being plugged in (Mini USB powered).
Apologies for sounding desperate, I'm leaving in a couple of days and the anker battery I was recommended turns itself off within 5 minutes of being plugged into my GPS and stays off unless I manually reset it. Which I can't do when I'm travelling. Can't find anything this specific on Google and various manufacturers keep saying "no problem" then "oh! wait a minute…". Apart from the very cheap ones which look as if build quality was not a core specification.
So…. Anyone know of a reputable manufacturer producing a USB battery that will….. just give me a potential difference without trying to be clever about it, and (preferably) not catch fire?
Thanks!
Evan
Good Answers: 70
Re: Looking for a 'dumb' USB battery
08/03/2015 11:51 AM
Why not just build your own battery pack without all the tech $hit. USB cords and multi-cell battery cases are cheap enough. That way you can build it to what ever capacity you want or need.
https://m.youtube.com/watch?v=iz-bu5aWZNc
Hobbies - CNC - New Member
08/03/2015 12:42 PM
Good Answers: 444
08/03/2015 2:29 PM
"... I want it to maintain the voltage until its battery is empty...", and therein lies the rub- "empty" is defined as the USB terminal voltage being below 4.75 V or 4.45 V for USB 3.0. The USB/battery power controller inside your GPS tells your device's power management system when the external voltage falls below that level and then switches to the internal battery. You can't fool it to accept a low USB voltage, it will shutdown the device if the internal battery doesn't have the required voltage.
08/03/2015 2:54 PM
Yep, that's fine :-) as long as it can hold the requisite voltage for a few days against a device that is only gently sipping sparks (the inernal 1300ma/h battery lasts a week under normal usage) then I'm good with that.
Re: Looking for a 'Dumb' USB Battery
08/03/2015 4:24 PM
I use a variety of these E-power and Panther power battery packs for all my devices when I go off grid....Just look for one that's compatible with your device...
08/04/2015 4:21 AM
You could complement your battery back with something like this:-
http://www.solartown.com/learning/solar-outdoors/guide-for-selecting-solar-backpacks-and-bags-taking-civilization-into-the-wilderness/
to make the best of both world.
On the otherhand it might not be a good idea, as I believe the weather in Wales isn't conducive with solar items. ;-)
08/04/2015 10:36 AM
You need to figure out how much average current your GPS uses over say an hour. Then multiply that time the number of hours you need it for. That will be your battery capacity in amp hours. Then take your GPS battery voltage and divide it by 87.5%. That will be the voltage required to maintain your GPS for the time period you need. For example, if your GPS has a 5V battery that uses 100 milliamps per hour and your trip is 72 hours then you will need a 6V 7Ah battery. Then make a constant current controller ( a regulator and a few resistors,) attach a usb cable to it you're good.
My internal monologue is saturated anologue.
Register to Reply 7 comments
dj95401 (1); DodgySolenoid (1); evanmjones (1); Original_Macgyver (1); RAMConsult (1); SolarEagle (1); Vincent.Jones (1)
