Previous in Forum: Blower and Motor   Next in Forum: Half-pipe Jackets as in ASME Scope?
Speed Governer in Steam Turbine
08/11/2015 7:15 AM
Could someone please explain to me the theory of operation of the hydraulic speed governer in a steam turbine???
cause my only understanding is the mechanical one which is connected to the turbine shaft and having those flyballs which with the governer can actuates the lever to open and close the governer inlet steam valve.
thanks in advance
Pathfinder Tags: "governer" "turbine" "speed"
Re: Speed Governer in Steam Turbine
08/11/2015 7:56 AM
You might want to check out some pictures which do explain sometimes better how things work:
https://www.google.com/search?=hydraulic+speed+governor+in+a+steam+turbine
Check the Image tab and have a scroll through.
Have fun!
08/11/2015 8:18 AM
Also check out Woodward governors; there are now electronic governors that replace the older flyweight designs.
08/11/2015 5:44 PM
08/12/2015 1:37 AM
thanks a lot for your efforts, the governor i have is woodward but i need to understand its components i see so many parts and so many pressures of oils , that's why i wanted to know how the cycle goes.
08/12/2015 1:52 AM
There should be a manual that explains that. If it has been lost, try contacting Woodward for a replacement.
08/12/2015 8:40 AM
This might be a little bit off-topic, but it's potentially critically important...
In addition to a speed-control device, a trip & throttle valve is generally required on big turbines. This is a critical safety device, designed to rapidly cut the steam supply off in the event of a runaway overspeed event or loss of lube oil pressure.
There are 10 kinds of people in the world.... Those who use binary code, and those who don't.
08/12/2015 9:00 AM
Theory = make the go fast not go so fast.
Recommend not using this piece of machinery until your knowledge and understanding are equal to the task.
Register to Reply 7 comments
IdeaSmith (1); karimzakaria (1); rashavarek (1); SolarEagle (1); Tornado (2); tribefan1952 (1)
